1.6tdi P0101 fault
Hi
Recently getting the flashing coil icon and the P0101 fault code
Changed MAF twice for OEM however doesn’t fix and causes the the fault immediately ( cold or warm weather)
Using a cheap Ebay MAF the fault only happens when the outside temperature is really warm weather 20* plus
Car still drives okay possibly slightly worse in warm weather
Anyone had the same problem?
TIA
Is it a CAYC engine?
It’s not your MaF, it’s the EGR starting to fail.
Read this - it will explain what you can expect to happen.
Thanks for the reply
CAYB 2014 On 60k miles? Egr failing ?
I thought maybe because it only seems to happen when the weather temp is approx 20 degrees then it might only be some plastic becoming supple or some metal clip expanding thats not directly connected to the engine
The cars temp doesn’t seem to make a difference
The cheap maf is obviously less sensitive then the OEM that triggers immediately
I have some domestic CO2 smoke alarm spray cannisters used for testing smoke alarms
If i give it a vacuum test
Could i just spray this into the air-intake after the MAF? Engine ON or OFF?
Or is there some other Pipe N75? Etc to test from?
TIA
Had the car undertray off
Tightened a few jubilee clips at the drivers front lower engine bay
they were quite loose
Not sure if these are coolant or air intake pipes
Car seems to drive slightly better
Hopefully this is the issue
Time will tell…
On 28/09/2025 at 23:49, mac11irl said:
Time will tell…
Fault keeps appearing
Installed the OEM maf instead of cheap Ebay one
Manual Gears feel slicker & generally feels slightly better to drive however it keeps throwing the following codes and the OEM puts it into limp mode with Air intake Fault code
-Maf fault code
-Air intake leak fault code
Hopefully its a hairline crack on some pipe
