Idle vibrations
Hello, does anyone deal with idle vibrations on steering wheel, arm rest and also a little bit in seat?
Its not a big problem, but definitely I can feel big difference from last week.
I am about to change engine mount on the left side and on the right side which is also for transmission
5Q0 199 262 BJ + 3Q0 199 555 G
2017, 4x4 DSG
Also, vibrations not changing when shifting from P or R or D, its always same so it shouldnt be gearbox..
Check how your engine is idling aswell, if its not idling smoothly/a bit off then it could the cam magnet which needs to be replaced as it is common on the 2.0 TSI engines
Engine is running smoothly without any issue.
I will try to replace engine mount on the left side and engine mount which is also transmission mount on the right side. Hope It will help.
