infotainment update
I have a Skoda Fabia 2016 - with the attached infotainment system.
Is that a Swing MIB2 (5Q0 035 842B) with hardware H30 and software 0359.
But the Android auto is temper-mental. It connects / disconnects repeatedly from my phone. Is there a firmware update for it which might give better App-Connect? Though I understand I may have to find the "train version". Not managed to get into the menu system to find that yet?
David
No, this is not Swing, this is Bolero. I sent you link in PM.
Thank-you for your help
David
After:
(i) buying a new SD card; and
(ii) locating the SD card slot in the passenger storage compartment (glove compartment)
I put in the SD card with the file into the slot in the storage compartment, but when I try the update from the settings menu I get the message
Error: no data available. Please insert a source with software update data or check the source.
I have tried both:
(i) putting the file MST2_EU_SK_ZR_P0369T.7z as you sent it on the card; and
(ii) extracting the contents of the file and putting them on the card
But I get the same message both times.
Any thoughts?
David
Managed to get the update started via a long press on the Menu button, rather than through the settings. BUT I now get this screen.
I can cycle between Retry, Skip and Skip all - but whichever I choose it keeps coming back here.
I have double checked that the contents of the file MST2_EU_SK_ZR_P0369T.7z were downloaded correctly, unpacked correctly, and completely copied onto the SD card.
So, for now - whilst not completely bricked - it is stuck in a very bad loop
David
@pab567 I can't contact you via private message. I have questions to ask you. Can you help me?
David
Looks that your EMMC is faulty - it mnisses some files, probably due to faulty sectors, and I guess this was the root cause of your probelms. If I am right then unit can be repaired either via manual formatting of EMMC or, if this doesn't help, exchange of EMMC chip.
What is your location?
Sorry for the delay in the response - I live near Stirling
@pab567 Sorry for delay between messages - death in the family :-(
Rather than trying to fix the EMMC chip (reformatting or replacing). Am I correct that you do updated units that fit behind the front display.
If so, and I went down this route:
  • can you supply
  • would they be more up to date that I can get with fixing the EMCC chip issues, and the current software update
  • what would it cost
Regards
David
There may be a maximum size of card that you can use.
With my VW UP! the maximum size of sd card was 32gb.
I don`t know if this is the same for the Skoda range but it might be worth trying a smaller size card.
Thanks - that is a really good point. I had originally used a 64Gb card, but then got a 32Gb card because I read about size limits. And it hasn't made a difference ☹️
Sorry to hear that.
Mugwump
Thanks. You inspired me to try again.
Took my 32Gb card and formatted it to less than 16Gb with the rest as unused space. Put the files back on it, and inserted it into the slot. Low and behold, the upgrade completed! So, my infotainment is back. Lets hope the Android Auto is improved. Going for a 3 hour drive north to Inverness this evening. That will give it a good workout.
I have just put my 32gb into the slot and it plays.😀
Is there a way to get random play of the music on it?
At the moment it starts from the beginning each time.
Glad to hear that you managed to get yours going.
To be honest, have never used the SD card for music. I only ever found the SD card slot for the first time when I was looking for the infotainment upgrade. So, sorry - can't help on that.
Hi Does anyone have MST2_EU_SK_ZR_P0480T available?. I believe this is the latest software version for 5Q0035874B
Thanks Andy
Edited by Andymod
Thanks Andy
Thanks Andy
@pab567
Edited by Andymod
@dacn I sent details in PM
@Andymod MST2_EU_SK_ZR_P0480T will NOT work directly on any unit that was manufactured with software different than 04xx (xx - any number). This means it will NOT work directly with 5Q0035874B. There is a way to push MST2_EU_SK_ZR_P0480T into 5Q0035874B but it requires unit to be patched first - google for MIB STD2 TOOLBOX.
Thanks for the info
On 11.09.2025 at 19:40, pab567 said:
Hayır, bu Swing değil, Bolero. Bağlantıyı özel mesajla gönderdim.
Merhaba forumda yeniyim o yuzden yanlışım olursa özür dilerim bende de H30 5Q0035840B seri multimedya var ve şuan yazilim sürümü 0359, varsa daha guncel sürümü benimle de paylasirmisiniz?
Edited by yns2626
This is English forum so pls use English language.
I'm new to the forum, so I apologize if I make any mistakes. I also have an H30 5Q0035840B series multimedia system with the current software version 0359. If there's a more up-to-date version available, could you please share it with me?
Hi, My son Has passed his Test and I have given him My 2015 Fabia 1.4tdi sel Unfortunately it does not have satnav not a problem for me It has The bolero 5Q0035820 Hardware H11 Software 0137 Codec: 1003.113.1.15 prod. I believe I will need a 5Q0035842A will this unit once purchased need to be sent off to make it plug and play with existing display or will it just plug and play as it is ... or am I better getting a Chinese Android unit ... Regards Simon
Forget Chinese Android units, you need Bolero 5Q0035842x / 565035842 or Amundsen 5Q0035874x / 565035874. New unit must be patched first.
