Retrofit ESP button
Hello!! My car only does have the start stop button as default, I bought a module with the additional esp and air pressure set buttons but I cant make it work, I have the vagcom so I can change coding but I am unable to find the bytes regarding this module:
Interruptor ESP Skoda Fabia III NJ 6V1927238B 1.0 44kW CHYA 312781
Thanks in advance.
What country is the car in / for?
What is it you actually want to be able to disable?
VW Group / Skoda, ESP = Electronic Stability Programme.
But then there is ASR / Anti Slip Regulation, or TC Traction Control. XDS / XDS +
TPMS / Tyre pressure monitor system. Reset.
Edited by Ootohere
Your car probably has an ABS module without that functionality.
Bought part info (3 button):
Part Number: 6V1927238BApplication: Skoda Fabia III NJ 5-door hatchback (2018+ facelift model)Engine Compatibility: 1.0 TSI 999ccm, 70kW (95hp) with manual transmission, Climate Control, and ABSProduction Date: May 4, 2025Internal Code: TMBE46NJ3JZ711304
My car is from Spain, also with an 1.0 TSI 95hp manual transmission. I also can disable traction control from my screen, it would be amazing to have the button disable the traction control and work as intended as in the car it is coming from
Partslink24 doesn't seem to recognise that VIN, is that your VIN? If not, what is yours?
I've always considered that not having a physical ESP button on newer cars is a bit of a backward step, okay normally you don't need to have to use it, but when you do, it helps if you can just press a button instead of searching for it in screen menus as time/momentum has been lost by then.
22 hours ago, wirer said:
You do know that the above link takes everyone that clicks on it, back to this thread?
Sorry. You only need to rewrite or copy the text and Google would find the page. Second attempt?
https://wirer.sk/f3_asr-esc/
