S3 FL - side assist and rear cross traffic assistant - retrofit problem
I am looking for help with my retrofit - Superb 2021; Virtual Cockpit, MIB3 infotainment . It was done some time ago, but it doesn't work properly from the start:
  • side assist seems to work ok - it reacts on both sides.
  • rear cross traffic assistant - not working at all (on the dash - error - unavailable). Usually not possible to tick on the dash; even if possible - each time I select "R" - beep + error on the dash.
Carscanner shows error:
3C. Lane change assistant3C. Lane change assistant
DTCs: 1
2240530 [0x223012]
U112300: Databus error value received
Parkhilfe_01::PH_Tongeber_H_verfuegbar. -> I was already asked if park buzzer works properly -> yes, it does.
I think that hardware shall be done properly, but something is wrong with coding. I googled a lot, but was unable to find coding for similar car to check it :/.
I found coding for 2016 Passat, but I doubt if this is the same:
[MQB] [Skoda SuperB] - Rear Cross Traffic Alert - Coding
Is anybody able to help me find the proper coding for Superb 3 FL (MIB3; VC)?
I normally use Carscanner, if needed I will borrow OBD11.
I can see a post in link Ross-tech topic:
My car:
ABS - byte 29, bit 7 is active
Module 76 - byte 3; bit 12 is not enabled.
Screen from ODB11 - Parking Assistance (76):
Edited by bobbest
Yes, in unit 76 set RCTA Active
I've coded that bit and I got big emotions - more than 50 errors occurred, even engine and transmission. I managed to clear everything, but something more is wrong :/. After coding, parking sensors became unavailable.
Are you able to help to find what more shall I correct?
Errors:
10. Parking Assistant 210. Parking Assistant 2
DTCs: 1
13632273 [0xD00311]
U112100: Databus missing message
Steuergerät für Anhängererkennung-J345 - Gateway_72.Anhaenger_01_alt - kein Signal/keine Kommunikation
Bity stanu: 1
Priorytet: 6
Częstotliwość: 1
Indeks: 85
Status: Test się nie powiódł, Potwierdzona
76. Parking assistant76. Parking assistant
DTCs: 1
13632273 [0xD00311]
Bity stanu: 1
Priorytet: 6
Częstotliwość: 1
Indeks: 85
