Coolant leak after servicing water pump and timing belt
Greetings,
While doing a water pump/timing belt renewal, I've inadvertently broken a piece off form the cooling system and I would like it identified.
It's on the right side of the engine and the best I can do is potentially identify the hose from the manual as being a hose to the exhaust gas recirculation cooler. But I don't want to lay a false scent.
I've attached an image and circled the two items I'm interested. The nipple has snapped off in to the hose hence I need both parts
TIA
-Anthony
15 hours ago, wolfie-smith said:
Greetings,
TIA
-Anthony
Edit: It's a cooling flange. £18.50 form Skoda
Part number?
As noted in y original post, it's an engine coolant outlet flange - 04L 121 131 AA
