Will it fit !!!
Hi guys, my partner reversed into something ( !!!) in her 2013 fabia VRs hatchback And has ruined the rear bumper !! I’ve been quoted £600 for a fix and respray !! On the bay of E i can get a green bumper from an estate of the same age, question is,will it fit ?? Any answers would be gratefully received Cheers
Sorry out of luck the hatchback model uses a slightly different rear bumper than the estate version i think it's the side parts that attach to the car are longer on the estate version, keep trying you will find one
Thanks for the reply murdockman, oh well the hunt continues !!! Maybe I’ll get some reverse sensors fitted for her as well !!!!!!!!! Cheers
I was rear ended in my hatchback, i replaced the bumper and bumper brace (you likely wont need to replace that part) from a parts car myself. For my 2013 fabia any rear bumper from any hatchback fabia mk2 will fit. Here differences all lay in the looks, wether it has parking sensors or not. Color, And weather it has a different trim level (like monte carlo ones have the black trim around its edges and eill not look good if your fabia does not.)
If youve never replaced a bumper before it can be fiddly, the tools youll need is simple tho, torx bits and pry tools (i used the same ones i used for my interior in other projects.
So, i would just cover it in ducttape and be on the lookout. Fabia mk2 is a fairly common car, so just register the part you want with a few different used parts dealers and wait till someone gets the correct bumper.
I dont know these similar websites in other countries. But here these companies use websites like bruktdel.no to list parts cars, and already disassembled parts. There may be something similar where you are.
Best of luck with this ^^
Thanks for the reply, I’m keeping an eye out for a bumper and in sure one will turn up at some time or another !!!! Cheers
