HELP! How to move drivers electric seat when not in car? Can I wire power from a battery without deploying airbags?
got an electric drivers seat from a 2023 superb out of the car and need to wire the seat to get power so I can move it forward and back whilst out of the car not worried about the memory function etc just need it to move forward back, I’m guessing I can connect the red yellow wire to positive and ground to negative but worried I will deploy the airbags.
Is No Problem Airbag is own Connector in Yellow normaly
What’s the requirement? I ask this because there is an option for something like Easy Entry, but needs coding
I believe the seat goes back when you open the door, then goes back to your set position with ignition on
Might be an option?
So if I connect the red/yellow (far right) to positive and brown green (far left) to negative, I should be able to move them?
@Cairus ⬆️⬆️⬆️
I will write, dont Worry...
Sorry just wasn’t sure if the forum would notify you cheers
Red/Yellow ---> fuse 20A---> 12V Potential --->1,5mm²
Brown ---> 0V Potential/GND---> 1,5mm²
No warrenty
Edited by Cairus
