2009 2.0 Diesel Octavia, Showing high coolant temp as soon as engine starts
I assume its a coolant sensor?
How do I locate it and how do I test it?
Thanks in advance
Its a BKD engine if that helps
Thanks I had seen that post but still cant fine the sensor!
On side of cylinder head towards battery under the MAF ducting. Fairly easy to replace but you'll lose some coolant. Pop an ice cream tub under it to catch coolant.
Bosch or Febi equivalent.
Thanks Its currently not on so I will keep a close eye on it
It could also be a connector or wiring fault in the sensor circuit.
