Issues with infortainment System in 2016 SE L Executive TDI Greenline Estate 56k miles
Just back from a road trip in my much loved superb Superb where the infotainment system worked perfectly as it has since buying the car 2nd hand in 2020.
The very next day it was glitching significantly.
Issues:
- all pre stored radio channels dropped out
- unable to set time, says switch ignition on when it is on
- unable to connect phones by bluetooth, says switch ignition on when it is on
- rear parking camera no longer viewable in the infortainment screen, audible sensors work
- when playing radio seems to turn off, seems ok when in Apple Play
Having read about possible fixes I have done the following:
- soft reset, holidng on / off button
- taken battery off for 30 mins and then reconnected
- gone into menus and done factory re-set
None of this seems to have fixed the issue.
Wondered if anyone else has had similar issues and what the potential causes and fixes are?
I assume it's a Columbus due to spec and it's installed with Canton Speakers.
Thank you and apologies of already covered elsewhere - I did check, honest.
