I have returned to a Superb 3 and I have a couple of questions
After a 4 year hiatus in a Fabia, I have traded up/down to an older higher mileage, but infinitely higher spec Superb 3 SE L Executive, 2.0TDI, 190 DSG and I am already in love again!
A couple of questions though. This model has AdBlue, the range is showing 0 but there is no warnings etc. Does this mean that at some point it has been coded out and I don't need to worry about putting AdBlue into it?
Also does anyone know if its possible to recode the physical buttons on the infotainment. I would like one of them to point directly to smartlink but there isnt an "APP" button on this unit.
99% - yes
Hi,
As far as I remember, if you have less than 2000 km Adblue autonomy left, you should have a warning popping up on the dashboard each time you start.
With a full tank of AdBlue, I used to have around 14000km of autonomy on my former Superb MK3 (also TDI190 equipped, with DSG6 4x4)
You have a FL version, with Columbus MMI, you should be able to rearrange the App icons as on a Smartphone. Then you just need to press the 'Menu' button and you'll have your favorite Apps on the 1st screen.
The car is coded, otherwise if the AdBlue range is 0 you cannot start it.
