All-wheel drive: Sport setting, how it works?
Hello
I'm driving a 2025 Superb MK4 Wagon 2.0 TDI 193HP 4x4 L&K. I'm so sad that the car is missing an Offroad and/or Snow mode (my previous VW Passat Alltrack was equipped with the Offroad mode instead, very much helpful for me that I'm driving very often over the Alps here in Italy with a lot of snow).
So I'm wondering which setting should I select when driving over the mountains in the snow to mimic the missing Offroad mode.
This is why I'm asking if (on top of selecting ASR OFF or ESC SPORT, in order to have some useful spinning in snowy conditions) I should act on the "All-wheel drive" setting inside the Individual profile.
In fact I noticed that my car has this capability, i.e. to change from Normal to Sport setting inside the All-wheel drive menu (please do not mix this with the Drive menu, which is a different one).
What exactly means the Sport setting here? Does it act on the Haldex system forcing more torque to flow to the rear axle even if no spinning is present?
Driving on clean roads in fact I have the impression that, once selected the Sport setting for the All-wheel drive, the Haldex system is operating with 50:50 torque partitioning even if there is no wheels spinning.
Any info/feedback would be very much appreciated.
Best regards
  • 4 weeks later...
AI: In the fourth-generation Škoda Superb (2024+), setting the 4x4 drive to Sport mode within the Individual settings primarily changes the torque distribution logic and the system's "eagerness."
Here is a breakdown of what happens technically:
1. Proactive Torque Distribution
In Normal mode, the 4x4 system (using the 6th generation all-wheel-drive coupling) is reactive, meaning it waits for a hint of front-wheel slip before sending significant power to the rear.
In Sport mode, the system becomes proactive. It sends more torque to the rear wheels immediately during takeoff or when accelerating out of a corner, even before any slip occurs.
2. Rear-Axle Bias
While the Superb remains a front-biased car, the Sport setting increases the clamping force on the AWD coupling more frequently.
The Result: The car feels more stable through corners, provides better "push" out of turns, and significantly reduces understeer (the sensation of the front end pushing wide).
3. Faster Response Times
The control unit communicates with sensors (steering angle, lateral G-force, throttle position) at a higher frequency. The system is essentially "primed" to react to changes in grip instantly.
4. Synergy with ESC
When you set the 4x4 to Sport, it works best in tandem with the ESC Sport setting. This combination allows for a tiny bit of wheel slip, which, combined with the active rear axle, allows for much more dynamic handling, especially on wet or snowly surfaces.
WOW! Thanks a lot for this precious info!
Edited by tommy_190
