Skoda 1.3 OHV and Head Gasket Failure - What we know so far
Understanding Head Gasket Failure (HGF) in OHV Engines
A structured guide based on long-term observations and practical experience
Head-gasket failure on these OHV engines doesn’t happen all at once. It usually progresses through several stages. Recognizing them early can save the engine from severe damage.
Stage 1 — Pre-HGF Symptoms
These are subtle and often overlooked:
  • Very slow, unexplained coolant loss, without residue on the expansion tank.
  • Residual pressure when opening the expansion tank cap after the engine has fully cooled.
  • BTB test may or may not be effective at this stage; if tested for long enough, CO2 presence will create enough carbonic acid to drop the pH and change the color of the indicator. A 30-minute test in a fully warmed engine should most often suffice.
Stage 2 — Early HGF Symptoms
At this point, the issue becomes noticeable:
  • Inconsistent radiator fan cut-in temperature, especially at idle. Increasing RPMs makes the fan behave more normally.
  • Dried coolant residue around the top of the expansion tank, especially near the mounting tab crevice.
  • Increased coolant loss (typically 100–300 ml per 1000 km).
  • Stronger residual pressure in the cooling system.
  • This is where a BTB tester will save you big time. USE IT!
Stage 3 — Full HGF
This is the final stage before major damage begins:
  • Bubbles in the expansion tank, especially when filled to the brim.
  • Hydrocarbon smell in the tank vapor.
  • Very inconsistent thermal behavior at idle.
  • Oil analysis will show water contamination; condensation under the oil cap becomes more noticeable.
Important:
Compression tests and leak-down tests often show no deviation at this stage.
This is your last chance to fix the issue before internal damage begins.
Stage 4 — Catastrophic HGF
At this point, internal engine damage has already likely occurred:
  • Oil and coolant begin to mix.
  • Coolant entering the cylinders leads to steam from the exhaust.
  • Rough idle, misfires.
  • Persistent overheating.
Compression tests and leak-down tests will finally show abnormal numbers here.
Damage to rotating assemblies is common due to poor lubrication.
Why Do These OHV Engines Fail Head Gaskets?
The number one cause is corrosion, not overheating.
Corrosion attacks the composite gasket and the fire rings, and may also attack the cylinder head.
Overheating is typically a symptom, not the root cause.
How to prevent it:
  • Perform frequent coolant flushes.
  • Use high-quality modern coolant — not cheap formulas and definitely not plain distilled water.
Are Some Engines More Resilient?
Yes.
Engines equipped with TEMAC factory head gaskets tend to be more durable. They rarely reach Stage 4 and often stay in stages 2–3 for long periods without noticeable symptoms.
However, owners who top up with distilled water accelerate corrosion dramatically.
What to Check When Replacing the Head Gasket
1. Corrosion
Check the area around coolant passages.
You do not need to machine the head until all pitting disappears — if there is 4+ mm of solid, flat surface, sealing will be adequate.
2. Head Flatness
  • Up to 50 μm deviation: no machining needed.
  • If you machine: avoid shops that take heavy cuts.
    • Maximum recommended pass: 25 μm (1 thou).
3. Liner Protrusion
Aim for: 100 μm
Acceptable range: 70–120 μm
Maximum deviation across all cylinders: 40 μm, while staying within min/max limits.
Best Head Gasket Options
The strongest choice currently available:
✔️ Payen BT581 with PTFE coating
Most other quality brands follow the original TEMAC design, which is now outdated.
Avoid cheap low-grade gaskets — they fail quickly.
Do the Head Bolts Need Replacing?
No.
The bolts can be reused if:
  • Thoroughly cleaned.
  • The block’s bolt holes are cleaned.
  • The bolts are lubricated.
  • They are tightened according to Skoda factory torque specifications.
Do I Need to Machine the Head Every Time?
No.
If the head is within flatness tolerance, clean it and reinstall it.
Only machine when required — and only with precision, not heavy cuts.
Final Notes
Identifying and addressing HGF early saves the engine from catastrophic failure.
Regular coolant maintenance and correct gasket choice dramatically increase longevity.
Edited by Thefeliciahacker
A great article. Well done.
Whilst still within edit period a couple of notes from my perspective.
BTB is not a common generally recognised term even a quick Google search (BTB test for a car) four pages in doesn't show up so could you consider putting an asterisk and later explanation, or a link to an explanation, or an additional more widely used alternative term.
For me on my PC the headings come out very large and bold, over large.
The other use of bold, and red, is good, again great article, well done for posting it.
Edited by nta16
ETA:
Just a suggestion.
Goggle search seems to find "block test" best term, I know some now seem to refer to it as a "sniffer test", so perhaps you could put something like -
BTB / block test / sniffer test
Damn its out of editing period hope mods can help if they want
You can but ask, I would try pressing the three-dot button at trop right corner of your original post and select 'Report' from the drop-down menu, select 'Other' from the drop-down menu below "Why do you want to report this?" and put in the optional message. There may be other and perhaps better methods but that seems direct enough to me and I think a Mod would be happy to help in a situation like this whilst perhaps reminding you of the 'Freedom' on the site options.
Good luck.
