New Octavia CD Autochanger won't load??
I have just purchased a Skoda 1.9tdi elegance DSG.
My 1st impressions are very good, the car has very smooth acceleration and is very comfortable.
Now for the downside.
I think there is a problem with the cd autochanger as I can't get it to load cd's. The manual doesn't indicate whether the ignition should be on or off and whether the radio should be on or off.
The only signs of life are when the ignition is on and the radio is on. In this mode I get both the eject and the load buttons lighting up. If I press the load button nothing happens. If I press & hold the load button I get all the cell lights lighting up in sequence, but still cannot load a cd. The lights go out after one or two runs through.
Can anyone help please.
Many thanks
AlanHeath1
IIRC you press the load button then the position in which you want to load it into.
Have you pressed the individual numbered slot button to tell the changer which slot you want to load?
beaten by lummox quick fingers!
Tried but still won't load. Should both the load and eject buttons be illuminated together??
to load you press 'load' then select a free position from the flashing buttons, then insert disc. To eject press 'eject' then select the cd you want to eject from the flashing buttons. If you hold down eject it will eject all the discs in turn after each other.
No need to have ignition on to do this
Thanks everyone, it's certainly not doing what you suggest it should so it looks like a trip to the dealership.
AlanHeath1
Do you have an Ipod link?
