a small project
A small project for my own vehicle in between other things...
Er, what is it?
Looks like a light surround for a latch? Looks like the seatbelt latch
The cigarette lighter was faster in the car
So, the first usable attempt at positioning the contacts for the eMMC chip.
Now for the mount, a prototype.
Some of the tips are defective, but OK for testing.
Today I manufactured ambient lighting for the 12V socket, of course controllable via the MIB.
Ready
First step
****, that's just awesome 😎
Rain Close
Bcm Software Version max. 0253 with mib2
All Other i will say After Check
Retrofitting Area View in a vehicle that did not have Area View from the factory
I've got a set of brand new red brakes.
On 02/03/2026 at 17:10, Cairus said:
Rain Close
Finish and Work
So, I got a MIB3.
Endless loading during user login.
Problem solved, fully unlocked, now updating to SW332 with full unlock and CP off.
Today I managed to mirror the Android Auto navigation instructions to the virtual cockpit. In a 2017 MQB Classic model.
Can you add more details?
If i have 100% solution, yes.
MIB3 Preh Unit Not MIB2
Found 100% solution
On 01/04/2026 at 21:45, Cairus said:
Found 100% solution
Can you share?
One step forward. Door connector replaced, cable pulled through, test connection in vehicle with new door connector.
almost finished
I quickly installed an MIB 3 and an OCU 3 in the O3 for testing during the holiday trip.
The wiring and OCU will of course be neatly installed.
I wonder if there will ever be a ethernet <-> optical solution for virtual clusters.
Since MIB3, the virtual cockpit has been connected via Ethernet. MOST is no longer used by VW, Skoda, and Seat. Audi still uses it with MIB3.
First Generation VC dont have Ethernet
  • 4 months later...
Virtual Cockpit used Tarraco Retrofit Leon.
Immo Change ans Miles
About all in 30 min
Recently Browsing 1
