Škoda Kodiaq 2019 Virtual Cockpit – Reduce Gauge Size for Bigger Map?
Hi everyone,
I have a 2019 Škoda Kodiaq with Virtual Cockpit and I’m wondering if there is a way to reduce the size of the gauges so that the navigation map becomes larger and more visible.
For example, on a VW Passat you can simply press OK on the steering wheel and the gauges shrink, giving more space to the map. On my Škoda, I can’t find any similar option anywhere in the menus.
I also have OBDeleven, so I’m wondering if this can maybe be coded or activated through adaptations?
Any help or experience would be greatly appreciated.
Thanks in advance!
Not doable. Passat has bigger screen and different firmware.
Just change your VC screen option to get a larger map
