Deleting attachments
Hello!
As I seem to have almost reached a small limit for uploading images, I require assistance for deleting older uploads to make room for some more, as I didn't see any available tool for that.
Thank you!
Morning,
If viewing on mobile -
Tap on your profile pic, to bring up the account menu, then tap on “my attachments”.
Select the files you want to delete, then tap on the Bin icon.
It’s probably very similar on a pc/laptop browser, but I can log into Brisky on my work laptop due to security restrictions by our IT dept..
Thanks for your answer! My Android browser doesn't give me any select option, unfortunately..
I was wondering if I needed extra badges/points to enable this kind of feature, or expand my quota. Well, I should try with another browser, as is the only alternative I see right now.
Thank you, anyway!
Thank you, anyway!
What browser are you using? I use chrome on my iPhone (work) and android (personal) phones
  • Dean locked this topic
  • mac11irl unlocked this topic
Chrome browser android. Can see my attachments in list but only option when clicking on pic is seeing it, nothing else.
You should be seeing this. Check boxes on the right to select individual attachments to delete and at the top a button to select all on the page.
Same but slightly different layout on a phone with Android.
Edited by Lee01
Don't see any check boxes
@Dean
Could you check is this a glitch?
Gould have the check box lower right
Of each attachment frame
  • Administrators
I'll check the settings to make sure everything is set correctly.
  • Administrators
OK, this is now fixed. However, it is a perk of being a FULL MEMBER. Not a 'Find my way'. There is a minimum of 49 posts which are required to enable this setting. Also, FREEDOM gets this perk too along with other increased profile settings.
A word of warning; any images attached to older posts will be deleted and break the flow of the topic. So, be mindful what you're deleting.
Edited by Dean
  • 8 months later...
speaking of attachments, is there a way to rename the attachments so i can easily find/search them, rather than scrolling n scrolling until i find it?
thank you
