Hazard lights on while charging battery
Flat battery on charge but hazard lights on
Sounds like the alarm has activated when you started charging it...
Could be the siren battery is flat as well or failed. Low voltage in main battery or siren battery can sometimes confuse alarm and set it off randomly. Hopefully it will settle down once system is back up to charge. My old Octavia thats sitting waiting repair alarm goes off if I let battery get to low. If it doesnt stop I would disconnect battery for charging.
Alasdair
