Inspection service
My car is up at the dealership next month.
Does any one know what is done on the inspection service ?
What service, how many miles or years old is the car? What was done last time? So UK there is no actual INSPECTION SERVICE. That is just the Service Indicator showing Oil Services and Inspection Services. At the PDI or the last Service they could have been set at the same time. So Variable / flexible services or Fixed. So it is an Oil & Inspection Service. Annual or do you want Variable? Extended Scope & 3 years then each 2. Be sure though at the Service they do a Body Inspection, for the Corrosion Warranty. That is not the INSPECTION Service though. . Extras cost. Pollen Filter, Spark Plugs, Air Filter, Brake Fluid, DSG Service etc etc.
Edited by Evolution13
100,500 ish miles on it. 2018 plate. Car was serviced by a skoda specialist prior to me pickingup the car.
Probably oil and filter change
Inspection of tyres, brake pads, quick look underneath for loose joints and oil leaks
Check coolant concentration
Top up fluids
Check any fault codes
Probably about it
@Stuart-h Really then it is get done what you want doing or needs doing. What did the Skoda Specialist do and when was that? Best if you say what your car actually is, engine and gearbox, rather than people needing to check your profile. So what service history has the car, and how many miles a year do you do?
My bad. 2 liter diesel with the manual 6 speed box.
Doing 10,000 ish miles a year.
