Trouble Shooting Octavia Mk2 1.6 tdi 2013 CAYC - 01314 Fault Code - No Start
Good evening,
I'm having a major headache troubleshooting a 01314 fault code no communication with ECU.
Have tested all fuses (not contacts), tested the main 100 relay in the engine bay as well as some of the relays under the steering wheel.
The car was driving fine the night before it happened then went to start the next morning and dash lights come on with a few errors not seen previously, most of them related to 01314 code.
I've had the battery tray out to inspect the wiring and there's one suspect plug connector junction which was very damp although had it open today and seemed dry inside the connector. The exposed coloured wires might need a closer look, I've attached a photo, possibly a coroded wire there but it was hard to tell with all the oil residue and muck so will give it a good clean up tomorrow.
The other suspect thing is the drivers footwell is sodden with water coming down the inner pillar onto the floor. I'd sealed this before but the seal looks like it's disintegrated. Possibly related to that one of the relays in the area where the water ingress may have impacted is all taped up and looks like someone's previously done a diy wiring job on it all wrapped in electrical tape (photo attached) and not fixed to the relay panel where it should be, so I can't tell exactly what the relay controls and whether that might be a culprit for the 01314 code.
The car is a 2013 1.6 greenline mk2 octavia CAYC
I've scoured the forums for days now and had a lot of help along the way thanks to all the previous troubleshooting but now running out of ideas.
Any help much appreciated!
Oh and forgot to mention, in the 3rd photo of the taped up relay there's what appears to be a loose black wire top middle of the image with some white tape wrapped around it. Possibly has always been like that or at least since the diy wiring job but I don't know for sure and until I know what that relay is for it's hard to say whether it would be the cause of the 01314 code.
Does the wire with the white tape look as though its been cut?
Alasdair
Hi Alasdair, yes it looks like it from the photo but I'm guessing would have been cut a while ago as we haven't had any work done on this area of the car previously.
I found the schematic (attached) for this upper relay area above the central control unit which is the LHD version (ours is RHD) so image needs to be flipped.
You can see from the photo in the 1st post we appear to only have 3 relays in that module (507, 646 and the unidentified taped up one). According to the schematic the taped up one must be D5.2 relay for heating element, 507 must be starter relay and 646 the horn. None of the other relays in the schematic apply as they're for things this car doesn't have.
So even if the taped up D5.2 relay were faulty/wet or badly wired I'm assuming it's unlikely it would be the cause of the 01314 code... so time to look elsewhere I'm guessing unless you think the cut wire could be related.
  • D1 – Relay for independent heater -J485- (for vehicles with an independent auxiliary heater) / relay for low heat output -J359- (for vehicles with auxiliary resistive heater (PTC))
  • D2.1 Horn relay -J4-
  • D2.2 – Fuel pump relay (for engine letters BUD, CGGA, BSE, BSF, CMXA, CHGA) / – Additional fuel pump  relay -J832- (for engine letters CLCA, CLCB, CFHF, CFHC, CEGA)
  • D3 – Relay for high heat output -J360- (on  vehicles with additional resistance heater (PTC))
    D3.1 – Relay for fresh air blower -J13- (on vehicles with independent auxiliary heater)
  • D3.2 – Additional heater fuel pump relay -J749- (on vehicles with an independent additional heater)
  • D4 – Starter relay 2 -J907-
  • D5.1 – headlight washer relay -J39
  • D5.2 –  Relay for heating element -J925- (at engine lettering CAYC)
Relay box on CBU
Here are also the list of fault codes for reference:
ABS:
01314 - Engine Control Module (ECM)
Power steering:
03803 - Steering Angle Sensor for Steering Aid: No or Incorrect Basic Setting / Adaptation
Instrument cluster:
12648448
Central electronics:
02395 - Parking light right front (M3)
Heater & air conditioning:
13701376
Radio:
00871 - Bass Speaker Front Right (R23)
Telephone:
9458451
CAN network gateway:
No idea if wire is related. I asked if its been cut and not broken in case its come off something but if it looks cut I doubt its come off anything. With the drivers footwell soaking wondering if its corosion/water in the BCM/connection. Think its in that area. Another point would be whats the condition of battery. Low volts can often cause problems.
Thanks for the insight mate, I wondered about the BCM/canbus connection especially with the water ingress, that was going to be my next port of call it's quite low right at the back so a bit of a b*gger to get to but would definitely be worth checking if I can.
I tried a new battery as the first potential remedy but didn't solve it unfortunately. :(
Think the BCM and ECU are closely linked and can cause no start if its not connected properly.
Alasdair
Ok great thanks again, will try and explore that further then and will report back 🤞👍
UPDATE:
I gave up trying to get the canbus module out from the interior as it was so far back behind all the relays and wiring, so followed this very good guide on how to remove it from the outside: https://www.r32oc.com/threads/canbus-gateway-location-removal.29242/
The good news is the canbus itself and connector both look bone dry and I think I can rule that out, the bad news is I've still not found the root of the issue. I would quite like to inspect the canbus module PCB though, does any one know how to release the 4 clips without damaging the plastic housing?
Tomorrow I need to check the connector points for the lower mounted internal relays and inspect for damp/corrosion etc there. One of the relays there did have what looked like a drip of water on the surface so we'll see. But my thoughts now are back to being that the fault is most likely rooted in the wiring loom to the ECU under the battery tray or somewhere around that area.
UPDATE:
Had a mechanic out to look and after turning the key first time the car started I couldn't believe it(!) magic touch! But it kept cutting out and was running rough with 01314 code persisting. I had had the canbus out a few days in the dry and had only just put it back so suggested it might be that, although he dismissed the canbus logic.
He did point out that the starter cable points on both ends in the engine bay looked quite corroded and might be the cause of the no start.
A few more days passed and a lot more rain, went to start it to drive to garage and no crank again, back to square one!
Today I cleaned and grinded the corroded points connected to the starter but still no dice, same issues.
The pillar and floor on the driver side is sopping wet (I haven't been able to seal the roof rail fixing area due to all the rain). It must be related to water ingress to the electrics in the cabin... possibly canbus.
If I fitted a temporary replacment canbus would I be able to tell if that has solved it without having to recode it ?
Still having the same issues, have explored some other avenues without luck yet, the problem is we're quite remote and local garages won't look at electrical faults so we're a bit stuck. Had a VCDS scan done using a mates scanning tool, there are a few suspect fault codes stemming around the drivers area which is where the water ingress occured originally (now sealed so it's drying out).
if anyone has experience interpreting VCDS and could point me in the right direction would be much appreciated! Cheers!
Gateway Installation List:  7N0 907 530 AG
01-Engine -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Chassis Type: 1Z-SK35 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 61 77
<VIN Removed>   Mileage: 333340km-207127miles
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BL    HW: 1K0 907 379 BL
   Component: ESP MK60EC1   H31 0152
   Revision: 00H31001
   Coding: 133B201C092200FCC80D04EA901B0091300000
   Shop #: WSC 73430 790 00064
   VCID: 7DF14CF3E4F16773AB-8028
1 Fault Found:
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 204
                    Mileage: 333347 km
                    Time Indication: 0
                    Date: 2020.02.24.
                    Time: 01:28:24
             Freeze Frame:
                    Count: 3
                    Count: 2
                    Count: 4608
                    Count: 8194
                    Count: 42752
                    Count: 0
                    Count: 0
                    Count: 0
Address 08: Auto HVAC (J301)       Labels:| 3C8-907-336.clb
   Part No SW: 3T0 820 047 AF    HW: 3T0 820 047 AF
   Component: AC Manuell    H20 0607
   Revision: 00001012
   Coding: 0010000003
   ASAM Dataset: EV_ACManueBHBVW36X A01010
   ROD: EV_ACManueBHBVW36X_SK35.rod
   VCID: 73E56ACBDAB52103CD-8026
1 Fault Found:
13701376 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 5
                    Reset counter: 204
                    Mileage: 333347 km
                    Date: 2025.10.03.
                    Time: 01:28:28
Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
   Part No SW: 1K0 937 085 P    HW: 1K0 937 085 P
   Component: BCM PQ35  B+  111 0709
   Revision: AC111709
   Coding: 48000AB8A05BB1904008008011000024430000AE424D81605CC5C7000041
   VCID: 3C7781F7BF6BAE7BDC-8068
   Subsystem 2 - Part No: 1Z0 951 171
   Component: Innenraumuebe  008 5101
   Subsystem 3 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
4 Faults Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 204
                    Mileage: 333347 km
                    Time Indication: 0
                    Date: 2020.02.24.
                    Time: 01:28:27
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.90 V
                        ON
                        ON
                        Term 50 On
                        OFF
                        OFF
00153 - Windshield Wiper Motor;  Driver Side (V216)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 204
                    Mileage: 333347 km
                    Time Indication: 0
                    Date: 2020.02.24.
                    Time: 01:28:27
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.90 V
                        ON
                        ON
                        Term 50 On
                        OFF
                        OFF
02395 - Parking Light Front Right (M3)
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 2
                    Fault Frequency: 8
                    Reset counter: 204
                    Mileage: 333347 km
                    Time Indication: 0
                    Date: 2020.02.24.
                    Time: 01:28:46
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.90 V
                        ON
                        ON
                        Term 50 On
                        OFF
                        OFF
00834 - Signal for Activation of Heated Rear Window
            009 - Open or Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00101001
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 244
                    Mileage: 333347 km
                    Time Indication: 0
                    Date: 2020.02.24.
                    Time: 03:55:16
             Freeze Frame:
                        Term 15 Off
                    Voltage: 12.25 V
                        OFF
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD2YGMTN
   Coding: 0020788
   VCID: 3D718CF36471A773EB-8068
   Subsystem 1 - Serial number: 6332MSME720059071
   Subsystem 2 - Serial number: 6342MSME72002F0EC
No fault code found.
Address 16: Steering wheel (J527)       Labels:| 5K0-953-569.clb
   Part No SW: 5K0 953 521 BN    HW: 5K0 953 569 E
   Component: LENKS.MODUL   014 0140
   Revision: FF010041    Serial number: 20121123800232
   Coding: 108A140000
   ASAM Dataset: EV_SMLSNGVOLWSXS A01004
   ROD: EV_SMLSNGVOLWS_SK35.rod
   VCID: 79F958E3F8D95B5387-802C
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 3T0 959 537     HW: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  H07 0012
   Coding: 820000
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 1Z0 920 943 S    HW: 1Z0 920 943 S
   Component: KOMBI         H06 0608
   Serial number: 00000000000000
   Coding: 410800
   Shop #: WSC 73430 031 00064
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
   ROD: EV_Kombi_UDS_VDD_RM09_004_SK35.rod
   VCID: 4999E823E8B90BD357-801C
1 Fault Found:
12648448 - Function Restricted due to Missing Message(s)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 204
                    Mileage: 333347 km
                    Date: 2025.10.03.
                    Time: 01:28:30
Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 AG    HW: 7N0 907 530 AG
   Component: J533  Gateway H53 1634
   Revision:   H53       Serial number: 131112F1000966
   Coding: 352303
   VCID: 75E154D3DCC13F33E3-8020
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 204
                    Mileage: 333347 km
                    Time Indication: 0
                    Date: 2020.02.24.
                    Time: 01:28:27
00470 - Company Comfort Databus in Single Wire
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 244
                    Mileage: 333347 km
                    Time Indication: 0
                    Date: 2020.02.24.
                    Time: 01:58:50
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H06 0608
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
   ROD: EV_Immo_UDS_VDD_RM09_SK35.rod
   VCID: 6ADB77AF8D7FE0CB7E-803E
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MIN3.clb
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2120
   Coding: 0131700
   VCID: 489FED273BB3F2DB48-801C
1 Fault Found:
01706 - Switch for Mirror-Adjust (E43)
            008 - Implausible Signal
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 69     3305
   Revision: 00H22000
   VCID: 377D9EDB464D8D2331-8062
2 Faults Found:
            000 - - - MIL ON
             Freeze Frame:
                    Fault Status: 11100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 333347 km
                    Time Indication: 0
                    Date: 2020.02.24.
                    Time: 01:28:31
             Freeze Frame:
                    Battery Volts: 12.0 V
                        DU
                    Temperature: 12.0°C
                    Count: 2
                    Steering Angle: 0.00°
                    Count: 0
                        SteerAng n.Init
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 204
                    Mileage: 333347 km
                    Time Indication: 0
                    Date: 2020.02.24.
                    Time: 01:28:31
             Freeze Frame:
                    Voltage: 12.00 V
                        DU
                    Temperature: 12.0°C
                    RPM: 1498 /min
                    Speed: 0.0 km/h
                    Speed: 0.0 km/h
                    Count: 0
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MIN3.clb
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0131700
   VCID: 479DEE1B36ADFDA341-8012
Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 1Z0 035 156 M    HW: 1Z0 035 156 M
   Component: BOLERO        001 0008
   Revision: -----08S    Serial number: SKZ4Z3M1182945
   Coding: 000002000001
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 204
                    Mileage: 333347 km
                    Time Indication: 0
                    Date: 2020.02.24.
                    Time: 01:28:31
Address 61: Battery Regul. (J840)       Labels:. 1K0-907-534.clb
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AG
   Component: Batt.regelung H53 1634
   Coding: 030F185A
   VCID: 71E960C3A8A913133F-8024
   Subsystem 1 - Part No SW: 1K0 915 181 H    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900529126
Address 77: Telephone (J412)       Labels:| 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 C    HW: 3C8 035 730 C
   Component: Telefon       012 0822
   Revision: --------    Serial number: 35909603489858
   Coding: 020000000100010000000000
   ASAM Dataset: EV_UHVPremi A02705
   ROD: EV_UHVPremi_A02_SK35.rod
   VCID: 23455A8B2AD5F183FD-8076
1 Fault Found:
9458451 - Cellular Antenna
          B1053 13 [00001001] - Open Circuit
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 204
                    Mileage: 333347 km
                    Date: 2025.10.03.
                    Time: 01:28:23
End-------------------------(Elapsed Time: 02:57)--------------------------
------------------------------14 Faults Found------------------------------
Please use do not post your VIN or reg number on the public forums, as data scraping may use this information for vehicle cloning or other activities. Only send this information via the PM (Private Messaging) function to trusted members. If the PM function is not yet available to you, tagging the member and asking them to start a conversation will work.
Briskoda admin.
  • 5 months later...
anybody found the solution? I read in another thread that the issue @SkodaLada had, was solved with a relay change. However I dont know which relay to change. I am having exactly the same issue. Already changed battery, checked all the ground cables, fuses and all seems ok. It is an intermittent issue, is happens when driving, sometimes when starting the car. The errors goes away by itself. I have an OBDeleven, I cleared the codes and it comes back.
Relay 458 in the engine bay could be the cause.
@Morph I dont have 458. I have 646 and 645 if I am not mistaken. (3x 646 and 1x 645) It is a Skoda octavia mk3. On the fuse box on the inside of the car there is 1 x 645 and 1 x 646.
Apologies I think I remembered this from a Golf perhaps!!
