DPF regen every 80kms
Hi - I'm new to Briskoda so go easy on me please 😁 I own a 2011 Skoda Superb diesel estate (CFGB engine). I did a lot of searching but couldn't find an appropriate answer. I have the VAG DPF app and recently did an active regen (pic attached). After only 12kms of normal driving, the dpf soot load went from 21% to 32%. That's 1% per km!! Any ideas of a cause? Car has done 244000kms and full service history with regular low ash oil. No codes using OBDII. Cheers Adrian Screenshot_20260215-115319.png
Hi all - I'm still having the same problems with my 2.0L TDi (CFGB engine). Active regens every 70-80kms!! Car has had the emissions-gate fix. Photo attached of VAG DPF screen after my latest active regen. Anyone shed any light? Thanks Adrian
Edited by adriantillin
Text changes
Hard to say, what sort of journeys are you doing ? (short/long)
Does the engine get up to temperature fully ?
My 2014 has the CFFB engine, the fix was applied by the dealer before I got the car (unfortunately!) but its been ok.
Used to get 220 - 240 miles between regens but this has dropped to 120 - 180ish depending on journeys.
I assume the shorter intervals must relate to gradual oil ash build up in the DPF.
No issues with engine temp. No codes either. Car does a variety of journeys (from town trips to Adelaide return - 4700kms).
It's the rate of soot production that I can't understand (256mg/km)
Get your injectors checked out. If they're failing soot production will go way up.
Thanks - will do
