2023 vrs towbar
Very confused and apologies if covered elsewhere but can't find it... looking to get a towbar fitted for caravan towing and an independent towbar company is warning about coding and about the rear emergency braking kicking in and not letting me reverse with the caravan in place. Another has said they can fit a towbar but I'd need to take it to a dealer to get it coded.
I've contacted my local skoda dealer and they've quoted £1900 for a towbar to be fitted!!
I think that when in reverse I can disable the reversing sensor via the infotainment screen by pushing the green camera icon, but not sure whether that will also disable the emergency braking.
Am new to caravanning and towbars so completely clueless.... any advice greatly appreciated
I've a 2023 Octavia Vrs hatch.
First thing to check is what your car can tow, a lot have zero Kg limit, and that would stop you towing, you can check on the sticker on the drivers door slam (thats where mine is) and then find a decent towbar fitter that can code as well as fitting the bar, I had a removable one fitted to my VRS estate and had it coded and if it is coded correctly you wont have any problems with reversing, as when you plug in it detects the trailer(Caravan) and switches off the system for reversing !
Appreciate the reply. Can tow up to 1600kg so all good there as caravan is max 1450kg loaded. The towbar fitter I spoke to told me that the 2023 models onwards have so much electronic stuff on it now that it's not as simple as before and a lot of independent fitters aren't able to do the coding. Apparently same with other car manufacturers and is designed to make sure you are forced to go to a main dealer and pay through the nose. I spoke to another towbar fitter and they said they can fit a towbar but for the same reason they weren't sure about coding and I might need to then take it to a dealer afterwards anyway, who aren't going to touch another persons work. Right pain. I'm no expert but apparently it's all to do with the car detecting there's an obstacle behind it and it slams the emergency (manoeuvre) brake on and refuses to reverse?
Where abouts are you in the country ?
I'm in Hampshire. One of the people I spoke to today reckon I need a different fan, fan cowling etc as the towing might overheat the car...wtf... I'm towing a small caravan not a 40t truck😁
I had a Westfalia towbar, who are the OEM supplier to the VAG group, installed to a Golf Mk8 last year, including coding, by this company in Poole.
Advanced In Car
Advanced In-Car Tech | Audi & Volkswagen Retrofit Special...
Advanced In-Car Technologies are the leading Retrofit Company In The UK. Specialising in Audi & Volkswagen Retrofits & Bespoke Aftermarket Electronics
Rear reversing sensors and blind spot sensors are turned off when a caravan / trailer is connected
Wez Morrell
Manchester
Wez Morrell
Manchester
0161 430 7591
I had mine done by this company I know it not near but give them a ring and see what they say ?
It's essential that a vehicle specific wiring kit is used that can integrate with the car's Canbus network, and that its coded.
Some of the cheaper options use generic wiring kits instead where the car is not aware that a caravan / trailer has been connected.
This leads to issues where the parking and blind spot detectors are not switched off.
We can supply & fit a genuine electric folding towbar with a 2 year main dealer warranty and 13 pin electrics. The installation is recorded against the cars build data, it's the same towbar they install from the factory.
Edited by East_Yorkshire_Retrofits
Advanced In Car
Thanks for the info, much appreciated and will give them a shout on Monday👍
Advanced In Car
19 hours ago, RADIOTWO said:
Wez Morrell
Manchester
Wez Morrell
Manchester
0161 430 7591
Cheers for the info. See how I get on with the company in Poole and maybe give them a shout👍
OK Dave, if you were a bit closer I would recommend East Yorkshire Retrofit as I have had some work done by them and the did a perfect job fitting a reverse camera, but would have liked the electric retracting towbar, but I guess the company in Poole will do the job right (hopefully at the right price) for you,
Good luck
I don't have any affiliation with the company in Poole other than being a satisfied customer, here in Essex I found it hard to find a VAG specialist to carry out the works, rather than a general tow bar fitters who may be fitting to a different make of car every day and not have a detailed knowledge of any of them.
So it was worth the drive for me, I guess it all depends on how close you are to a specialist you can trust.
  • 3 months later...
Hello! I know this is a few months old but wondered if there’s an indicative price foR a 2026 vrs combi? I haven’t bought it yet but the car is out of factory already and I don’t think it has towbar or prep done. I’m potentially travelling from south to Crewe to collect. Thanks in advance!!
Assuming you got all this done and it’s as good as OEM??
