3 zone AC not working
Hi everyone,
I’m having a problem with the 3-zone Climatronic in my Skoda Superb B8 and I can’t figure out what’s wrong.
My car originally had a working 3-zone climate control. I replaced the Climatronic control panel to add seat heating buttons. After installing the new unit (part number 3V0 907 044 DA), the system behaves differently:
  • The 3-zone climate control menu disappears from the infotainment system
  • The rear vents only blow hot air
  • The rear flap motor does not move at all
  • Rear climate cannot be controlled anymore
When I reinstall the old Climatronic panel, everything works normally again:
  • 3-zone climate appears in the infotainment
  • rear climate control works
  • flap motors move normally
Things I already tried:
  • Copied the long coding from the original unit to the new one
  • Checked adaptations
  • Basic settings / flap motor calibration
But the problem remains exactly the same.
Both units have the same hardware version (HWH34), so in theory they should support the same functions.
My question:
Is it possible that the new unit has a different dataset (2-zone configuration) and therefore disables the rear climate? If yes, is there a way to flash the correct dataset to the unit using ODIS-E?
Any help or experience with this would be greatly appreciated.
Thanks!
