Knob Off - DSG
I need to replace the shroud/switch unit that sits around my DSG gear selector, I've pulled the trim up so it's now sitting underneath the gear knob.
So, any tips on how to remove the head of the gear knob so I can slip the shroud over it in order to replace it please?
Thank you my lovely people.
Mike.
Kodiaq 2017 2.0 DSG
Edited by Sallyday10
See attached. I've included the Superb section that is before the Kodiaq steps since it has a few piccies that may help.
Key points seem to be
  1. Avoid depressing the lock button during removal and replacement - if you do there is a procedure to reset it
  2. You need a new clamp to replace the one that is removed, along with accompanying tool.
Good luck
D4B805232CF-Gearbox 0D9-DSG-extracted.pdf
Hi,
thanks so much for this guide, very useful indeed!
I've removed the gear knob, but the lock button is now depressed 'in', do you have the procedure to reset the lock button please?
Thanks,
Mike.
Good luck
Rather than keep sending you snippets, you can download the whole guide here
In that thread you can also download a whole collection of the Workshop Manuals
  • 4 weeks later...
I sourced the 'special tool' from Temu, and managed to reset the DSG button so it was in the 'out' position. Refitted the knob and the surrounding trim panel too.
Thanks for the advice and guides.
