Should I swap for 1.8tsi? any good engine
Suddenly my job as relocated to Ulez zone in Upminster from Brentwood in May, my Octavia 2.0tdi won't be qualified. The new job premise have car park so I won't have to use train as it is shocking expensive.
I was thinking to swap same type car but to 1.8tsi or 1.4tsi are free Ulez.
I want like to know if these engine are bulletproof, I have read few says timing chain is only weakest of the engine range, anyone experienced on TSI please share if are good or should avoid.
Thanks.
The wife has a 1.4 TSI DSG Octavia FL and it's a great engine, more than quick enough when needed, but also economical when driven gently, often returning 50mpg+, I would have no hesitation in recommending this engine.
I have no experience of the 1.8 TSI but have heard 2013 and older versions can consume lots of oil, later ones are better, hopefully someone a bit more knowledgeable than myself may be able to clarify the 1.8 strong/weak points.
Blimey! that sounds bad, I did not expect these VAG have so many issues with TSI. I better thinking twice what to do next. Thanks for the link :thumb up:
One more question are the 1.4TSI timing chain or rubber belt? I looked on Google it shows both timing are chain and belt.
Age / generation dependant. Euro 6, cambelt.
