Electric seat not working properly
Hi, recently got a 2022 Superb Sportline Plus wagon.
The drivers' memory seat works by recalling the position, but it always needs a press of the rear base height to get it where I like it (on the lowest setting).
Also, all previous Skodas I've had have needed the SET and numbered button to be held down together to get the bleep and setting saved, but this one will only beep when you release the SET button and then press a numbered button. Could this be related?
Any help appreciated.
Edited by brucie286
There's another post a while back here about this. You can't save the seat position in any of the extreme positions.
You can turn off the personalisation so that it doesn’t link to your key. Then it will not reset to the saved position when you open the car. That way you can leave it in the extreme position that you like.
Obviously this doesn’t work if there are multiple drivers of the car with the seat settings saved to each key.
Brilliant, thanks. I'll give it a go.
Key personalisation is off and still wont work. I guess defsix is right and it just won't save at the lowest setting.
Yes. It won’t save the lowest setting but with personalisation off it shouldn’t move from the lowest setting everytime you unlock the car.
When it’s set to the key it moves to the saved setting everytime you unlock. If it’s at the extreme it will move away from that slightly to the position that it did save.
Bit without key it shouldn’t try to reset itself each time so as long as no one presses the memory buttons the it should stay where you want it to be.
