2016 Fabia Radio Update
Hi, new Fabia owner here.
My radio has Smartlink enabled, but my phone (Samsung Galaxy S22+) does not connect at all.
There is a thread on this forum which suggests that updating the software to the 1800 version, but I'm not sure how to complete the update.
Is there somewhere to download the software, and do I put it on an SD card and put it in the slot in the glovebox?
Details are;
Device part number: 5Q0035874A
Hardware: H25
Software: 0245
1800? There is no such firmware, for sure not for your unit. I sent you link to download MST2_EU_SE_ZR_P0253T which is thsn't help pls let me know.e most recent firmware for your unit, if it doe
Hi, thanks for the quick reply and the PM.
The 1800 came from this thread, though I guess it is a different unit.
I downloaded the folder you sent, unzipped it, and put in on a empty formatted SD card.
When I put it in the car I get the message;
ERROR: VARIANT CONFLICT
MEDIUM: DEVICE DOESNT SUPPORT THIS
(MAIN UNIT: VARIANT)
Do you know what causes this?
I have done some research - I used mib-helper.com to put in my current software version; MST2_EU_SK_ZRP0245T
It says
2. Latest available firmware updates:
Latest official firmware update: MST2_EU_SKZRP0245T
Does this mean I am on the most current firmware and I cannot update to the 0253 version which you provided @pab567 ?
I can see I sent you link to SEAT version instead of SKODA, sorry. have just resent the right one MST2_EU_SK_ZR_P0253T.
Of course you can upgrade to , you entered your train incorrectly (MST2_EU_SK_ZRP0245T, the right one is MST2_EU_SK_ZR_P0245T):
@pab567 Thank you very much, this is very helpful!
I will try with the correct 0253 update.
On the mib-helper website it says the latest possible firmware update is 0480, is it worth updating to that one rather than 0253?
It's possible but it requires unit to be patched first, also the metainfo2.txt file must be modified. Is it worth? There are no new features, just new skins.
That makes sense, thank you very much for explaining and for providing the correct files.
The update completed successfully and I can now use a wired connection to connect my phone using Android Auto
Good afternoon. I have a Škoda Superb with version 253T and I would like to update it, even if it means patching it and modifying the metainfo. Could you give me information on how to do it?
Hi @pab567
Can you help me?
Best Regards
@oabraldes what is part number of your infotainment unit?
This is my unit
All you need is MIB STD2 Toolbox and google
The problem is that I don't know how to continue from here. I'm attaching screenshots.
Use tools menu to patch SWDL
I’ve already run the “Patch tsd.mibstd2.system.swdownload to accept any metainfo2.txt” patch. Can I go directly from 253T to 480T now, or do I still need to modify the metainfo2.txt first?
From which menu should I start the firmware update?
Yes, you go directly from 253T to 480T now. Just keep in mind metainfo2.txt from 480T must be modified to (check for "RequiredVersion" tags and change non-zero values to 0.
Good Morning
I already patched SWDL and modified the RequiredVersion values in metainfo2.txt to 0, but when I try to install the firmware from SWDL through Test Mode, it still says that the current software version is too old. I’m attaching a screenshot.
@pab567 I only modified the two RequiredVersion entries and changed them to 0. I did not modify the RequiredVersionOfDM values.
RequiredVersionOfDM must be modified as well
There’s something strange going on because most of the packages show as N/A and only inic is available for update. cpu is also showing as N/A, together with main, mapupdate, personalpoi, etc.
Does this mean 253T is too old and I need to flash an intermediate firmware before 480T?
Also, during the update, should I untick/disable the esd_sec package to keep the toolbox and patches?
I’m also attaching my modified metainfo2.txt in case you notice something wrong with it.
metainfo2.txt
OK, I knnow wher ethe problem is but I am not able to help you, pls drop me reminder in PM in the evening (9 PM CET).
I still don’t have enough privileges on the forum to send private messages. I’ll write to you here on the forum later this evening instead.
ok
