Auxiliary water pump failure
Im getting codes P26f7/f8/fa indicating the failure of the secondary or type C auxiliary waterpump.
Can anyone tell me where this is located on 2023 2.0 TDI (200bhp) engine plz?
Also, if anyone knows the name of the manufacturer Skoda use for this part.
TIA.
Just a quick update ...TPS say they are 3 types of waterpumps ( aux & main) so not sure which one i would need ...does anyone have an idea which one it will be or if i run a code check on a decent device will that determine it?
Decent obd reader should give you the part number causing the fault code or at least point to it by name that you can then interpret.
Edited by Binx1310
Just ordering a obdeleven gen 3 "pro" as we speak
