Kodiaq lights upgrade
Hi everyone
I'm upgrading headlights on a 2022 kodiaq from basic led to matrix (8IT basic LED) To: 8IU adaptive LED. Need a map of adaptations for 09 to correctly code them in. Anyone with vcds who can provide me with that please?
Many thanks in advance.
Thanks very much that was helpful. Now some of the faults have disappeared but still don't have full functionality.
Are you able to provide full file? I want to check both settings to check if I haven't entered some sections wrongly previously. also there is a field with long light configuration code I think I might need that.
Did you only adjust the BCM? The LCM unit 4B also needs to be recoded and probably its data set adjusted. Is the assistant camera also correctly coded and using the right data set? Please post an autoscan.
And yes, I have a complete vehicle control unit image from a Matrix LED vehicle.
With vcds you can Not Finish this Retrofit
I am only upgrading the lights and adding rear height sensor, without a camera.
Installed modules for lights and 4b are from kodiaq already so dataset should be correct. I tried to reflash them with odis but it didn't work as originally it didn't come with these modules and system refused.
I tried adaptations from pre lci kodiaq but there might be some differences.
If you could provide a full map file that would be very much appreciated as I could then check all the channels if I haven't messed some up.
thanks
You Dont have the Assistent Kamera in the windshield?
Don't get me wrong, did you even research beforehand what you need for the retrofit?
Unit 4B have by Matrix a Other Dataset and Coding
Matrix Work with Assistent Camera unit A5 Other Coding and Dataset
Edited by Cairus
No assist camera no, installing without beam assist.
Did think it will be a bit more straightforward I must say.
Are you able to provide the full channel map please?
You won't get the vehicle running without Error Logs.
I am ending my support here because matrix headlights, if not correctly installed and adjusted, can massively disrupt oncoming traffic.
Edited by Cairus
I realise its a possibility but I've gone too far now and need to get at least lighting to work. I might install a camera yet.
Have you go the file ready or do you need to read it?
thanks
You won't get the lighting to work if the control units aren't correctly coded or parameterized ---> control unit data set... I also asked for a current vehicle scan.
Thursday,04,June,2026,14:59:14:45700
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 26.3.0.0 (x64)  HEX-V2 CB: 0.4713.4
Data version: 20260320 DS375.1
www.Ross-Tech.com
Chassis Type: NS-SK37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 22 2B 42 44 4B 52 5F 75 BB
          BC D6 D7
VIN: <REMOVED>   Mileage: 50496km-31376miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Cannot be reached 0100
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
4B-Multifunc. Module -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
75-Telematics -- Status: Malfunction 0010
BB-Door Rear Drv -- Status: Cannot be reached 0100
BC-Door Rear Pass -- Status: Cannot be reached 0100
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
Address 01: Engine (J623-DTSB)       Labels: None
   Part No SW: 05L 906 022 KB    HW: 05L 907 309 T
   Component: R4 2.0l TDI   H80 2005
   Revision: EBH80---    Dataset Number: V03935325ML 0001 CVN: 244293E7914A6D2022E7CED8914A6D2043FB2DAA
   Coding: 0125003203261D0830000000000000000000000000000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_ECM20TDI01105L906022KB 007001
   ROD: EV_ECM20TDI01105L906022KB_SK37.rod
   VCID: 71BFD185212232C230D-8024
   VINID: <REMOVED>
5 Faults Found:
4527 - Coolant Fan Control Circuit 1
          P0480 00 [10100111] - Electrical Malfunction
          MIL ON - Not Confirmed - Tested Since Memory Clear
28388 - Coolant Pump 3
          P26F4 00 [00100111] - Electrical Malfunction / Open Circuit
38317 - Mass Airflow Sensor 1
          U060F 00 [10100111] - No Communication
29987 - Coolant Pump for Intercooler
          P2B83 00 [11101101] - Over-Speed or Air in System
          [Charge Air Cooler Coolant Pump "A" Overspeed/Air In System]
          MIL ON - Confirmed - Tested Since Memory Clear
4708 - No Communications with HVAC Control Module (J301)
          U0164 00 [00100111] - -
Readiness: 1 1 0 1 1
Address 02: Auto Trans (J743)       Labels:. 0BH-927-711.clb
   Part No SW: 0GC 300 013 E    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2803
   Revision: 00H06V13    CVN: 43118CEA
   Coding: 0014
   ASAM Dataset: EV_TCMDQ381061 001001
   ROD: EV_TCMDQ381061.rod
   VCID: 2615F2D9D86C257A95F-8072
   No subsystems:
No fault code found.
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 GA    HW: 5Q0 614 517 BN
   Component: ESC           H35 0114
   Revision: 00000000    Serial number: 60762000001368 Dataset Number: V03935347XP 0001
   Coding: 6007929F50210B6E477C070662C34806490AD0E2E046127530615578D2094A0B00002F641A1B13111435351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 049015
   ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
   VCID: 76B5E299484C15FAE5F-8022
4 Faults Found:
4410 - Indicator Lamp in Auto-Hold Switch
          C1156 14 [00001001] - Open or Short to Ground
8356 - Databus
          U1122 00 [00001001] - Implausible Message
          [FCAN: Klima_11_alt veraltet bit is set]
32833 - Switch for Electric Parking Brake
          C100C 01 [10001001] - Electrical Failure
32837 - Lamp in Switch for Electronic Parking Brake
          C1145 13 [10001001] - Open Circuit
Address 05: Acc/Start Auth. (J518)       Labels:| 5Q0-959-435.clb
   Part No SW: 3Q0 959 435 Q    HW: 3Q0 959 435 Q
   Component: VWKESSYMQB    037 1400
   Revision: 00037000    Serial number: 0596052918 Dataset Number: V03935351DS 0001
   Coding: 0F20000723
   Shop #: WSC 00033 790 00164
   ASAM Dataset: EV_KessyHellaMQBAB 004055
   ROD: EV_KessyHellaMQBAB_004_SK37.rod
   VCID: 48C95C617238D30A473-801C
Address 08: Auto HVAC
Cannot be reached
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 EA    HW: 5Q0 937 084 EA
   Component: BCM MQBAB MxL H44 0511
   Serial number: 01102212302352 Dataset Number: V03935432RP 0001
   Coding: 000000000000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_BCMMQB 022001
   ROD: EV_BCMBOSCH_022_SK37.rod
   VCID: 7BA3F3AD736E48929A1-802E
   Wiper motor control module:
   Subsystem 1 - Part No SW: 567 955 119 B    HW: 567 955 119 B
   Component: J400FRWISCH  067 0070
   Serial number: 907353F0302209303489
   Coding: 104D0D
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  054 0206
   Serial number: SBY22M05D03H15M37S04
   Coding: 00885D
   Anti-theft alarm system sensor:
   Subsystem 3 - Part No SW: 5Q0 951 172 A    HW: 5Q0 951 172 B
   Component: Sensor, DWA  005 0403
   Serial number: 000000000ZL2209405VA
   Alarm horn:
   Subsystem 4 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000002419415
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 521 KH    HW: 5Q1 953 569 J
   Component: Lenks.Modul  H14 0190
   Serial number: 0100260420220C200818
1 Fault Found:
539157 - Databus
          U1121 00 [00001001] - Missing Message
          [Klima_12 Datenbus fehlende Botschaft]
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-283.clb
   Part No SW: 3Q0 919 283 D    HW: 3Q0 919 283
   Component: PDC 4 Kanal   H08 0055
   Serial number: 001801219448040 Dataset Number: V03935350P  0001
   Coding: 0001050011
   ASAM Dataset: EV_EPHBO14VW3260000 007018
   ROD: EV_EPHBO14VW3260000_SK37.rod
   VCID: 38292CA102D8A38A373-806C
Address 13: Auto Dist. Reg (J428)       Labels:| 2Q0-907-572.clb
   Part No SW: 2Q0 907 572 AA    HW: 2Q0 907 572 D
   Component: ACCCONTIMQB   H09 0396
   Dataset Number: V03935383SB 0001
   Coding: 3204600110FF8728749C812400408700000000000000000004
   Shop #: WSC 99999 999 2097151
   ASAM Dataset: EV_ACCMRRCONTIVW376 003018
   ROD: EV_ACCMRRCONTIVW376_003_VW37.rod
   VCID: 73B3DB8D5B3E00D2C21-8026
2 Faults Found:
2082 - Databus
          U1123 00 [00001001] - Received Error Message
          [FAULT_EPB_SWITCH_FAIL]
1389 - Function Restricted due to Insufficient Voltage
          U1400 00 [00001000] - -
          [FAULT_VBAT_BUSMON_LOW]
          Intermittent - Confirmed - Tested Since Memory Clear
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5QF 959 655 AT    HW: 5QF 959 655 AT
   Component: Airbag VW22   015 0755
   Revision: --------    Serial number: 00301AFP2177WH Dataset Number: V03935361FG 0001
   Coding: 98CCC0C0000000005C5450CF008840000065
   ASAM Dataset: EV_AirbaVW22TS6VW48X 001036
   ROD: EV_AirbaVW22TS6VW48X_SK37.rod
   VCID: 2809FCE1D278330AA73-807C
   Crash sensor for side airbag: driver side:
   Subsystem 1 - Part No SW: -----------    HW: 454 002 403 22
   Component: SideSensor_Df  008 0887
   Serial number: 35700000000E375D5E5
   Coding: 2D2D2D
   Crash sensor for side airbag: passenger side:
   Subsystem 2 - Part No SW: -----------    HW: 454 002 303 22
   Component: SideSensor_Pf  008 0887
   Serial number: 35800000000387556A5M
   Coding: 2D2D2D
   Crash sensor for side airbag: driver side rear:
   Subsystem 3 - Part No SW: -----------    HW: 454 801 804 22
   Component: SideSensor_Dr  301 0148
   Serial number: 35100AC129B1F000000R
   Coding: 2D2D2D
   Crash sensor for side airbag: passenger side rear:
   Subsystem 4 - Part No SW: -----------    HW: 454 801 904 22
   Component: SideSensor_Pr  301 0148
   Serial number: 35200DCD59C1F0000004
   Coding: 2D2D2D
   Crash sensor for front airbag: driver side:
   Subsystem 5 - Part No SW: -----------    HW: 454 800 403 22
   Component: FrontSensor_D  304 0149
   Serial number: 3550066A88C1F000000-
   Coding: 2D2D2D
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 565 920 951 D    HW: 565 920 951 D
   Component: KOMBI         304 8400
   Dataset Number: V03935346BG 0001
   Coding: 27A4001CA380A60001886A011001000800600000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009071
   ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
   VCID: 1E65DA39803CFDBADDF-804A
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AL    HW: 3Q0 907 530 E
   Component: GW MQB High   524 5463
   Serial number: 06052210520164 Dataset Number: V03935359PU 0001
   Coding: 030100045F28730023100240100F00010001070000000000000000000000
   GVL: 01C43C0000000600400C80008000C80000000000000200000000000000000000
   ASAM Dataset: EV_GatewNF 013026
   ROD: EV_GatewNF_SK37.rod
   VCID: 79AFE9A579527A8288D-802C
   Generator:
   Component: 5-01-14-01-04
3 Faults Found:
131654 - No Communications with HVAC Control Module (J301)
          U0164 00 [00001001] - -
          [Timeout Knoten 0x46 / 08 - Steuergerät für Klima]
66304 - Databus
          U1124 00 [00001001] - Additional Installations Detected
          [Mehrverbau CAN]
197169 - Controls in Steering Wheel
          U108E 00 [00001001] - No Communications
          [MFL (LIN#2) Timeout]
Address 22: AWD (J492)       Labels:| 0CQ-907-554-V1.clb
   Part No SW: 0CQ 907 554 J    HW: 0CQ 525 130
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00022.03.22 Dataset Number: v1260x015G0 0000
   Coding: 0101
   ASAM Dataset: EV_AllWheelContrHA1VW37X 004013
   ROD: EV_AllWheelContrHA1VW37X_004_VW37.rod
   VCID: 4CC1607166403F2A63B-8018
Address 2B: Steer. Col. Lock (J764)       Labels:| 1EA-905-861.clb
   Part No SW: 2Q0 905 861 B    HW: 2Q0 905 861 B
   Component: ELV-MQBB      H09 0040
   Serial number: 22000089455009 Dataset Number: V03935342UT 0001
   Coding: 0800000000000000
   ASAM Dataset: EV_ELVMarqMQBA0 002004
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 323D1E89E4A449DA097-8066
Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
   Part No SW: 5Q4 959 393 P    HW: 5Q4 959 393 P
   Component: TSG FS        009 0911
   Serial number: 0000458826246  Dataset Number: V03935351XF 0001
   Coding: 001000208001020000001100
   ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
   ROD: EV_DCU2DriveSideMAXHCONT_SK37.rod
   VCID: 50F974018A681BCA1F3-8004
   Left rear door control module:
   Subsystem 1 - Part No SW: 5Q0 959 408 E    HW: 5Q0 959 164 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  007 0011
   Serial number: 00000000000059747520
   Coding: 1D0200
1 Fault Found:
196660 - Motor for Window Regulator
          B1487 54 [00001001] - Missing Calibration / Basic Setting
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  130 1082
   Dataset Number: V03935310ZH 0001
   Coding: 01170000
   ASAM Dataset: EV_SteerAssisMQB 015157
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 74B1D8915E3007EADBB-8020
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 17052111603215 Dataset Number: V03935295XH 0001
   Coding: 000000070900037600003D01190000000000000000000000000000000000
   Shop #: WSC 00033 790 00176
   ASAM Dataset: EV_MultiModulContiVW48X 003003
   ROD: EV_MultiModulContiVW48X_003_VW27.rod
   VCID: 372B2F9D0FC6ACF23E9-8062
2 Faults Found:
66881 - Databus
          U1123 00 [10001001] - Received Error Message
          [LED_L_falsch_codiert received error value]
66882 - Databus
          [LED_R_falsch_codiert received error value]
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 392 P    HW: 5Q4 959 392 P
   Component: TSG BFS       009 0911
   Serial number: 0000458744659  Dataset Number: V03935351WV 0001
   ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
   ROD: EV_DCU2PasseSideMAXHCONT_SK37.rod
   VCID: 4FFB777D97560432069-801A
   Right rear door control module:
   Subsystem 1 - Part No SW: 5Q0 959 407 E    HW: 5Q0 959 163 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  007 0011
   Serial number: 00000000000059792280
   Coding: 050200
1 Fault Found:
Address 5F: Information Electr. (J794)       Labels:| 3G5-035-MIB-HGH3.clb
   Part No SW: 3V0 035 820 H    HW: 3V0 035 820 H
   Component: MU-O-ND-EU    H22 0306
   Serial number: SKZAZ2A0337598  Dataset Number: V03935351FR 0001
   Coding: 33261008000020000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB 001001
   ROD: EV_MUOIMQB_001_SK37.rod
   VCID: 33331B8D1BBE40D2021-8066
3 Faults Found:
0006 - Antenna Amplifier 2 for Radio
          B126E 13 [00001001] - Open Circuit
0005 - Antenna Amplifier 1 for Radio
          B126D 13 [00001001] - Open Circuit
7169 - Function Restricted due to Interrupted Communications
          U1110 00 [00001001] - -
          [A/C system (0x01) - function restriction due to communication error - BapErr_retry not successful]
Address 75: Telematics (J949)       Labels:* 5WA-035-28X-V1.clb
   Part No SW: 5WA 035 284 G    HW: 5WA 035 284 B
   Component: OCUGen3High   H20 0143
   Serial number: 0000000201VIHJ9 Dataset Number: V03935359XV 0001
   Coding: 032610101969A8809025460161052607
   ASAM Dataset: EV_OCUGen3High 003007
   ROD: EV_OCUGen3High_003_VW27.rod
   VCID: 4ACD66696C34211A517-801E
4 Faults Found:
7234 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [Climate Master (0x42) - Funktionseinschränkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
9457427 - Speaker for Emergency Calling
          B14A6 13 [00001001] - Open Circuit
12866049 - Databus
          [Airbag: Error value received]
0048 - Databus
          [Clima: No communication]
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-572.clb
   Part No SW: 992 941 572 CE    HW: 992 941 572 C
   Component: LED1L         H08 9202
   ASAM Dataset: EV_LLPGen3LKEBODPO68X 001003
   ROD: EV_LLPGen3LKEBODPO68X_001_VW27.rod
   VCID: 6889BCE112F8F30A673-803C
1 Fault Found:
131081 - Headlamp Type
          C119F 00 [10101111] - Implausible
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-572.clb
   Component: LED1R         H08 9202
   ASAM Dataset: EV_LLPGen3RKEBODPO68X 001003
1 Fault Found:
End----(Elapsed Time: 01:24, VBatt start/end: 11.6V/12.0V. VIgn 12.0V)-----
------------------------------37 Faults Found------------------------------
Please use do not post your VIN or reg number on the public forums, as data scraping may use this information for vehicle cloning or other activities. Only send this information via the PM (Private Messaging) function to trusted members. If the PM function is not yet available to you, tagging the member and asking them to start a conversation will work.
Briskoda Admin
Thats current scan.
Ignore some faults as car is stripped.
I do need to check full light adaptations in 09 module before I can go further with this.
Which Scan?
posted above its pending approval
Ok
Did you modify the wiring at the headlight connector or just swap the plugs?
No Scan!!!
4B have the wrong SW Version and wrong Dataset and Coding
D6 & D7 wrong because 4B wrong and wrong Dataset D6/D7
Edited by Cairus
Yes headlight connectors were modified, additional can added.
Makes sense. Are you in possession of correct files that I can flash them with odis e? odis s won't svm them.
And the full adaptations/coding for 09 and 4b?
Many thanks
You have VAS 6154A?
Yes have genuine odis setup.
I can help remotely, but I no longer do that for free because, unfortunately, people don't appreciate it.
All Other per PM
Edited by Cairus
