DPF worries
Hi again.
I have a 1.6 tdi
My daughter recently had to sell her VW Sharan after the DPF was pronounced dead. At least 2K to fix,probably much more.Her car was low mileage,full service history.
Can I protect the DPF on our much older vehicle,are there options if it clogs up?
Thankyou
The low mileage part is probably what killed it - TDIs need to be driven in order to regen the DPF.
You can be kind to it by taking it on a proper run once a week or so, and get it flushed.
Thanks Occy. Sounds simple enough!
A DPF isn’t like a GPF - it needs to be taken somewhere above 40/50mph for 20/30 mins and allowed to heat up in order for it to regen.
You don’t absolutely need to do it every week - but I’d try and give it a run once a fortnight. Equally, it depends if you’re taking it 45 mins to work every day, or crawling around town with it.
Thanks again I'll make sure it gets a run regularly.
Hello
Agree with DPF problem many posts about it at all group VAG engines.
Low city kilometers... solution -- make a forced DPF regeration
------SERVICE REGERATION OF PARTICULATE WHILE DRIVING ( IDE01637)
Just try to help somebody in future. Cheap and good.
my car Octavia 1.6 TDI 2018 (20k km year, small daily km)
165.000 KM
Re used cable REAL V2 chip ST32F429 ( clone purchased 2023 copy from ross-tech usa from aliexpress 32€ .New cable, another china 2026 chip for new models like skoda IV 2020 --75€)
patch cable REAL V2 firmware with ---NEW VAG VAGCOM_EEWriteLang (aliexpress licensed 10€) When conect laptop to internet or antivirus block cable and software so try to use an old laptop)
uninstall old version VCDS 23..
Install clean 26.3 + VCDS loader same folder
USe this old computer with windows vista with no antivirus no firewall NO INTERNET.
VCDS procedure:
-OPTIONS-test -save values (k1 ok k2 ok CAN ok) cable conect to ECU with all protocol )
-enter at 01 ENGINE
enter - 16 - SECURITY ACCESS
log in ---S12345
27971
04 BASIC SETTINGS
select---IDE01637 SERVICE REGERATION OF PARTICULATE WHILE DRIVING
Also possible at garage ..
20 min drive at 4th gear 2000-2500rpm
values at DPF lowed
Repeat operation FORCED REGENERATION on demand.
Good luck and patience
Edited by manuellllllll
Thanks for the info. Some serious tech there!!
