RAPID SPACEBACK 1.2 2014 MFD
I have just changed the oil and filter on my Rapid Spaceback 1.2 Petrol but cannot seem to reset the message 'Change engine oil' from the display.Any advice please.
Try a google search for the reset procedure for your particular vehicle - it may possibly be the same as MkIII Octavia and Fabia - Press and hold Odo reset switch, then turning on ignition, etc.
Thanks for that.I will give it a try.
If your reset procedure is the same, I've found it can be a bit 'fiddly' and can take a few repetitions to get right - there are two separate schedules - oil and inspection, toggling between them to reset the desired service schedule reminder.
Yeah, Tried this and got to the 'Are you sure you want...........,' but havnt found out how to get on the 'OK' message which appears after I have entered 'Yes'
Try pressing the RH side of the ODO rocker switch to confirm reset.
Great.Thanks for your answer. Sorted
