2013 Yeti TDi L&K Boot Floor height with/without spare wheel?
I have a 2013 Yeti with the spare wheel under the boot floor. I understand this raises the boot floor. I am looking to get rid of the wheel and have a lower boot floor, releasing more space? Hopefully?!..Does anybody know if a kit is available of what parts are required, or even if it is possible to retro fit? With 2 children every inch of extra space would be appreciated!
If your spare wheel is a Steel wheel, the saving of space is so little, as I would suppose you would have a compressor, jack & wheel brace instead.....
Plus, you get the benefit & assurance of having a Spare if you ever get a puncture. ☺️
We went from one Yeti to another and I reckon it's about a 15 cms height loss. Is it worth stripping the polystyrene blocks out either side of the wheel well and then visualise it you could get a plywood board cut to fit under the boot carpet? Maybe put a sheet of high density foam below it? I think it's a case of how you support the floor above the wheel well. Good luck !
Perhaps you just take out the spare wheel and fill the space with bits and pieces as necessary and will fit plus odds and ends in the polystyrene blocks. If needed you could put a simple support under the floor. You'd get a decent amount of extra space without any work and then when/if you decided to put the spare wheel back it would just go straight in. I'm all for a simple life.....
