Aircon not cooling at all: solutions?
Hello!
With the Heat we are experiencing in these days in Italy (more than 30º) I decided to use the the aircon, as last Summer it was really wonderful BUT with my surprise it doesn’t work!
I thought there was no gas in the tank but test said there was; I also put new from the beginning but nothing changed: Skoda mechanic told me he doesn’t hear the compressor starting.
Thinking to the works I made on the car, I realized I replaced the climatronic panel with the one with heated seats and since then I didn’t use the aircon.
I also made a soft reset (aircon + front vents buttons pressed with ignition on and car not started), I heard the flaps moving, but nothing changed!
I also read I need to coding ait again via OBDELEVEN (it’s necessary after a front panel/compressor are replaced) but I don’t have anyone close to me who has it.
Any other suggestion meanwhile?
No it’s not! 😭
Quote 'Skoda mechanic says he doesn't hear compressor starting' is a little concerning - the A/C compressor does not 'start' because it is permanently driven unless the drive shear plate has failed.
I'd take a close look at what was done during the changes to the climatronic panel.
Edited by Warrior193
added information
I checked the part numbers of Climatronic panels:
1. The Factory fitted of course didn't heat the seats so it looks like putting it back (had no time yesterday) everything should work again;
  1. The one fitted (and actually installed) supports ONLY front heated seats (and I have also retrofitted rear ones) and according to Skoda mechanic it comes from a 2017/2018 car (mine is a 2022 FL);
  2. I found another panel that supports BOTH of front and rear heated seats (and it comes from a 2022 FL)
I'm not sure that I can upload the dataset on the second one in order to make it work but I'll try while waiting for the third one. Always Skoda mechanic told me early climatronics as the second one, even if looking like the third one, have a different way to support the aircon compressor/pump so he suggested me to look for one like the third one.
Re-installed the factory fitted and aircon works again! I now believe putting the panel with heated front/rear seats support and without remote heating/front power windshield supports ii should have the aircon keeps on working
