Advice on repairs: Front oil seal leak + shocks
Hi,
I've got a 2015 octavia scout mk3, manual 2.0 diesel, with 135,000 miles. It's service is due. It's looking expensive!
In the last service there were some advisories. These were:
Front main oil seal starting to leak
Rear prop shaft starting to split
Front arm rear bush delimitating
Both front shocks leaking
Haldex service due
Brake fluid due
I've asked my local VAG independent garage to do the service. They say that to sort out the oil seal leak they will have to also replace the cam belt and water pump. The cam belt and pump were replaced in 2022, due to a fault in the previous one installed in 2020.
Do you think I should replace the cam belt again so that the oil seal can be replaced?
Should I replace all 4 shocks or just the 2 fronts that are leaking?
There is a slight strange noise (kind of an echoing rumble) coming from the rear of the car, and the car sometimes judders when accelerating from stationary. Could this be something to do with the prop shaft splitting?
The garage said they will assess the prop shaft before replacing it.
I have the same issue with the crankshaft seal, I've waited until my timing belt was due, I've been lucky I was only loosing 0.5l per 15000km. Personally I would monitor it if it gets worse then just get it done and the timing belt as well, but if it's ok wait until you do the timing belt.
I would only do the 2 shocks that are blown, whilst doing all 4 will give it a uniform feeling I would save money where you can.
