Fuel usage
I have a 2014 diesel octavia estate 1.6 blk edition. Lately, and since service my mpg is alot lower than normal. I understand my car is old but recently ive noticed im using more fuel.
Ive asked my usual mechanic and hes replied with the expected answer i thought hed suggest which is weather, tyres, speed, fuel prices and that mpg is never ro be trusted. Im not taking fuel prices into consideration as im seeing my fuel being used up more. Mpg today has been 34,on a route i normally use and get 55mpg.
I use the car everyday to commute to work using same route and speed and definitely see variation in mpg amd fuel consumption.
Any tips or ideas?
Appears that it might be something to do with the brakes as the drivers side front wheel is warm and can smell oike something is burning after a small drive.
Binding brakes could be the problem - how much hotter is the 'warm' one to the opposite side?
Another possibility is failing DPF regens, that can seriously affect fuel consumption and cause a burning smell.
Theres no heat or smell coming from opposite side just drivers side.
I think you can also rule out the weather.
My fuel consumption reduced noticeably in the spring, when the temperature started to increase.
Yup my mpg always better when spring arrives.
Anyway its a brake issue as had someone look today and will know more tomorrow
Had seized piston calipers so all sorted now
Good to hear a positive outcome.
I've always wondered how a caliper becomes stuck/seized over time..
Usually corrosion and/or 'road gunk' build-up around the caliper piston seals - which also serve to retract the pistons slightly when brake pressure is released.
I've had such a thing a few times over the years on various cars, usually after changing brake pads.. this means the pistons being pushed more back into the caliper, and the faintest smear of surface rust has been enough to make it all stick.
Glad it's sorted, @chrisski
