Boot liner 2026 Kodiaq (5 & 7 Seat convertible)
I’m looking for a boot liner for the new Kodiaq I predominantly use it in 5 seat mode but also want it to be able to be easy to switch to 7 seat mode when I occasionally use it. I looked at Hatchbag but they only do one or the other.
Has anyone else found a good quality solution to this that I can get before the Labrador fur sets in?
Hi there,
The boot liner for 7 seater is made in such a way that you can use it both for 5 and 7 seats. It allows you to individually put up the 6th and the 7th seats, or put them both down. The original one I mean, no idea about the aftermarket ones, though I did not see anything of good quality unless almost as expensive as the original one. Now, for this kind of car, you should go with the original, it is well made. Not sure I can sau the same about mudguards, but that is a different story...
Cheers!
1 minute ago, koditzadispater said:
Hi there,
Cheers!
Thanks, I take it you mean the Skoda OEM one, it is not really clear to me which one is which and they only seemed to do the floor and not the sides.
Do you have a link/part number by any chance?
The 7 seater OEM boot liner only covers the floor.
Thanks I thought that was the case, yet to see anything for the sides but it may be easier to keep them clean than the whole floor.
I bought a BootBuddy for my 19 pate Octavia Vrs Challenge estate, now using it in my 23 plate Kodiaq Vrs, it's got a rigid plastic base, sides and back, can be bought as an extending version that can reach to rear of front seats when rear seats are folded, contains all the dog hair. I always have dogs in a cage.
