Headlight o/s not levelling
Hi all,
My RH headlight is not self leveling, whereas the LH is. I therefore assume it is not the suspension sensors as I believe these feed both. Is there something like a poor connection that can affect one side?
Hope someone can help me track down the problem. The car has had the headlight removed when the condenser was recently changed, if that has any significance.
If it happened after headlight removal I would remove headlight again and check that all wiring is secure/no corosion/no breaks. It could also be coincidence and the motor in headlight has failed. Perhaps a scan with vcds would ping up a code or point to any underlying problems.
Alasdair
I had this, while having a small spate of electrical gremlins. Replaced the battery (which was totally knackered) and cleaned up all the earth points in the engine bay, and it's working just fine now.
Edited by chrisund123
I’ve had 1 not working after removal. Didn’t have any ecu connection methods at the time. Took a punt that it might’ve got forgotten about as such (don’t know the correct terminology or cause but it worked) so I unplugged the module and plugged it back in and it worked again.
