How do I save the settings?
Kodiaq 2026 PHEV
I set the lane control to 'Off', set the alert control to 'off', and various other settings that I want. But when I next switch the car on, all my settings are lost and I have to re-set them. This is a complete pain in the ass. How do I save the settings so that they stay set?
No way...I think....
I'm pretty certain you can't save those settings... From memory the EU mandated they 'reset' each time. The car is switched off and on.
Edited by skomaz
I agree^ - it's a euro NCAP safety thing I believe. The safety systems such as lane keep assist, speed warning, emergency braking etc can be disabled but reenable each time the vehicle restarts.
Luckily the Skoda has the quick access button on the steering wheel, with the assist menu so you can disable what you don't want. Some cars you need to enter the settings menu on the screen which is a bigger faff.
Edited by buaan
There is one other setting - drive mode - which always resets to normal. I drive most of the time in eco mode for fuel saving reasons, using coasting wherever possible. This is not NCAP related so I fail to see why this setting cannot be 'held' until I choose a different setting. Just another thing I have to adjust before driving - irritating.
In manual says clearly, for legal reasons...so it must be something mandatory there as well....
IIRC, try adding your desired setting on Individual and then use that mode. You still have a change to do, from Normal to individual, but still better.
The driving mode emphasizes eco-friendliness rather than safety. It resets itself to prevent the use of modes that harm the environment (sport, individual, etc.). It would have been smarter not to reset it if the driving mode is ECO. However, Skoda kept the implementation simple by resetting to normal regardless of the last driving mode. :|
Which simply highlights the idiocy of Skoda's approach.
All new cars are the same now, some are easier to turn off, but all will reset every time the car is turned on again.
This, and as somebody who this summer took delivery of a brand new Kodiaq after test driving a multitude of other manufacturers (a special mention to Kia who make it infuriating, with the settings buried behind 4x menus!), the ADAS systems on Skoda aren't anywhere near as intrusive as other brands. 2x (or 3x if you want lane assist off also) quick presses of a button on the steering wheel and it's off. No rooting around menus. We have it easy.
