After market radio recommendations
So I am now the proud owner of three head units. One which is locked and I can't decode. One with a broken screen which works (except for display) and one that is a piece of crap aftermarket one which won't turn on.
For my sanity, please could someone recommend a decent unit, that doesn't require me to cut wires, that is not a piece of crap and fits into the existing trim and doesn't look terrible.
There's so many out there and it's hard to know which ones are good.
Maybe better with another original. Have heard that aftermarket radios can interfere with OBD port communication if scanning. Someone on here may know aftermarket units that dont cause problems.
Alasdair
Alasdair
I don't know if I can buy another OEM one when I have 2 already. Tempted to attempt to repair the digitiser in the one that came with the car. But assume that's another rabbit hole that will end in wasted money.
replace the display?
Maybe try one of the companies that decode radio from serial number on working one
Loads on ebay and online like https://radiocodelookup.com/
Alasdair
Yea I'm leaning towards doing both (repair and getting aftermarket unit)
Alasdair
So none can seemingly help. I am told 'The server is down' but I think this means they do not have access to the VAG database. I believe they used to buy access tokens from garages. But I think the legacy VAG system is being discontinued and the new version is harder to exploit.
It may be possible for dealer to pull up code. Had similar in older volvo. Took v5 to show vin and serial number of radio and they got it for me. If locked one isnt from your car you could always take the original in and explain its to replace it.
Alasdair
