Opinions for new shocks+springs
i never had ones. but sure stiffer than stock.
On 06/09/2026 at 18:58, Jo88Mak said:
Thx for the reply. You didn't find the eibach pro kit too firm for daily driving?
Also i thought that for optimum performance you should use b8 shocks with the pro kit because the oe-spec shocks would wear out faster, thus the use of shorter shocks like the b8's.
I selected these after going thru the Octavia VRS forums on FB and this was a popular choice. Firmer but bearable I would say. H+R and Eibach Pro were the most common springs alongside OE shocks, although the H+Rs seemingly do go a bit lower (especially at the rear) and are firmer than the Pro's.
On 19/07/2026 at 17:36, Jo88Mak said:
Hello to all you good people!
I have a 2015 Octavia 2.0 Tdi Vrs estate/combi that has now 245k kilometers on the dash.
I'm thinking about changing the front and rear shocks+springs and all the associated parts.
The current ones are still original from the factory and while they passed Mot the ride isn't that great anymore.
I'm also installing a new Golf Gti clubsport RARB+links, new bottom&top suspensions arms and track rods in the rear axle. In the front axle i have changed already new lower control arms+ball joints, antirollbar links and inner+outer track rod ends.
This car is my daily driver with 80/20 highway/town cruising and i'm thinking that i'm going to keep it for another 2-3 years atleast.
What do you suggest i should get? I wasn't thinking of lowering the car from the standard vrs ride height and would appreciate a comfort ride that has that "sportiness" when i have the feel to go fast through corners and roundabouts etc. I understand that you can't really get the best of both worlds so its always a compromise.
And here in Finland the roads are not in that good condition especially after winter so I don't want too firm ride that corners like Mika Häkkinen getting away from Schumacher in Suzuka Grand Prix😅 but most of the time makes you feel nauseous from every single pothole/uneveness that our roads have to offer.
I'm thinking of going with new oem vrs springs like lesjofors and bilstein b4 shocks. Would that be the best solution for a daily driver or is there something better to be had with spending a little more money, like Koni Special Actives or Bilstein B6? Not going to get any coilovers for a car this old.
Thanks for the replies!
I am in the same boat - need a freshen up for my vRS estate, 79K miles and a leaking N/S damper
70% motorway use and like to push on in the other 20%
What did you go for in the finish (if you have?) The B4's?
Recently Browsing 1
