Update applications Kamiq
Hi
Every time I drive my Kamiq, it asks me on centre display if I want to update applications
I always click yes.
Today it asked again - so I clicked on more info, to which I got this message.
What do I need to do to fix this please anyone ?
Thanks in advance
Steve
Some applications cannot be updated while you are driving. Try stopping the car, apply the handbrake and see if the app will update with the ignition on but engine off. Also check you are not on max privacy.
If it won't then a trip to the dealer my be needed.
How do you check this max privacy ?
I get the update message regularly on the radio display, selecting an option appears to do nothing
You cannot normal update while driving.
Park the car where there is good signal. Ensure you are not in max privacy mode.
With the ignition on activate the update process via infotainment. Wait for a message telling you it's finished before starting the engine. Normally turning off the ignition and locking the car halts the process.
I'm usually driving at the time, so your saying I have to be parked up to update
@ johnnnie47. Yes that is exactly what I was saying.
Today only a short trip out to fill the tank, as usual within a few yards of travel the 'update' message appeared, this was an ideal opportunity to do the install when I got back & parked up in the garage overnight, however the plan was not straightforward, once back home for the life of me I could not find any way to get 'Update' back on the screen, I must have been sat over half an hour pushing buttons, cursing Laura [no help at all] going through the manual, still no wiser which info out of 3 screen I've got if it makes a difference. Eventually managed to get UPDATE appear at the top left of the screen, gave it a press with no response, should it at least tell you its in progress ? Anyway, did as informed, got out and locked the car, now got crossed fingers
