MK1 Front wheel bearing pack tightening torque
Hi All,
Does anyone know the tightening torques for the front wheel bearing pack, please?
(a) the three splined screws that hold the bearing pack in from the back of the hub and;
(b) the big, 24mm, 12-point hub nut that goes into the end of the driveshaft
If it's of any use to anyone, various bits of cross-checking online seem to indicate that the most common answers were:
(a) 70 Nm plus 90 degrees of rotation.
(b) 200 Nm plus 180 degrees of rotation.
  • Sponsor
A lot of difference there, which did you use, and why?
No, they're different fasteners. There are three smaller screws that hold the bearing pack to the aluminium upright. Those are "a" - the "70 Nm plus 90 degrees" ones. Then there's the big M16 x 1.5mm screw that goes through the wheelbearing and into the end of the driveshaft. That's "b" - the "200 Nm plus 180 degrees" one.
To be honest, both felt "about right" when I was tightening them.
