Reverse Camera Fitting Guide for mk4?
I have bought and successfully installed this one https://www.aliexpress.com/item/1005006263043091.html it should be the same one and OEM! The seller referred me this manual https://aiduauto.com/blogs/installation-manual/skoda-octavia-mk4-evo-rear-camera-install?srsltid=AfmBOor_4VQeI-8HV9o051odIiFk-0o78mooUIBaezjqMjpBkbpe8d1o
For disassemble interior I have followed this guide https://youtu.be/rWVycZsKrEU?si=EgI1TYuyRBRKmzvB
It was quite a strenuous job and I wouldn't attempt it again, however camera fits and works excellent just like original, a big improvement IMO.
PS: be extremely careful when disassembling tailgate wiring grommet clips.
Edited by mmt
Thanks! That looks great! Did you have to do coding to the car?
Yes, adaptations and coding via OBD11 pro subscription needed
Hi, what instructions did you use? All 3 pins to connector under steering wheel or 2 pins to connector and 12v pin to fuseboard? Thanks
Edited by Weeguy
I connected on my mk4 2020 all 3 to gateway t32 connector but I got plans to connect red wire to fuse box probably when I will be doing heated steering wheel so you can use both methods
