Enyaq clicking noise
Morning all.
Have a new issue I thought I would run by you to see if anybody has had similar....
2021 Enyaq 60 with 110k miles.
Have recently had starting a 'clicking' noise when moving away from a standing start and then when breaking. Almost sounds like a relay opening/closing. Strangely enough, if you pull away VERY slowly, it does not do it.
Car is at the dealer for a number of issues but, on this one (no diag done by 5 on Monday but completed by 11 yesterday), it has been declared as a major job requiring 10 hours of labour to power down, remove gearbox and carry out repair. All very vague at the moment and have asked for a breakdown of parts required.
Quote for the repair is £3,300 !!!
My initial enquiry is whether anybody has had similar please??
If this needs to be done, then so be it, but a bit miffed that a 4 year old car with (relatively) not high mileage, requires an expensive repair like this !!
Will add to my post if/when I get an update of requirements....
Thanks in advance,
Paul
Sounds very much like the drive shaft splines need to be re-glued. (Yes! Glued!)
I've had MEB cars for over 5 years and this issue has been raised a number of times on various forums. There is a clicking sound from the rear when moving off (forward or reverse) and when going over to full re-gen. The splines on the drive shafts have movement caused by the adhesive used on them failing. All cases I've heard about have been covered by warranty or extended warranty. Worth a Google.
AI says,
As vedicle is outside it's original 3-year manufacturer warranty, consider these avenues to manage the cost:
Ask for Škoda "Goodwill": If you have a full Škoda main dealer service history, ask the service manager to submit a goodwill contribution request to Škoda UK. Because TPI 2065531/1 acknowledges a known manufacturing design tolerance issue, they sometimes cover a percentage of the labor or parts.
Edited by AndyMorris
Many thanks for this info.
I have asked for a breakdown of the parts required and costs
Many thanks for the info. Have asked for a breakdown of the parts and costs. Will have a better idea if the same issue you mention then...
21 hours ago, AndyMorris said:
AI says,
Many thanks for this. Once I have a definitive answer to the issue, I can use this if it is the known problem.
Many issues / faults are KNOWN ISSUES to VW Group, Dealers / Technicians. Maybe even with a TSP / TPI, yet time after time, 'Never heard of that before', nerer seen that before, and sometimes 'they all do that'. The VW way. 3 monkeys or Tommy. Deaf, dumb and blind. The internet really has stuffed it up for the VW group.
