Enyaq clicking noise
Morning all.
Have a new issue I thought I would run by you to see if anybody has had similar....
2021 Enyaq 60 with 110k miles.
Have recently had starting a 'clicking' noise when moving away from a standing start and then when breaking. Almost sounds like a relay opening/closing. Strangely enough, if you pull away VERY slowly, it does not do it.
Car is at the dealer for a number of issues but, on this one (no diag done by 5 on Monday but completed by 11 yesterday), it has been declared as a major job requiring 10 hours of labour to power down, remove gearbox and carry out repair. All very vague at the moment and have asked for a breakdown of parts required.
Quote for the repair is £3,300 !!!
My initial enquiry is whether anybody has had similar please??
If this needs to be done, then so be it, but a bit miffed that a 4 year old car with (relatively) not high mileage, requires an expensive repair like this !!
Will add to my post if/when I get an update of requirements....
Thanks in advance,
Paul
Sounds very much like the drive shaft splines need to be re-glued. (Yes! Glued!)
I've had MEB cars for over 5 years and this issue has been raised a number of times on various forums. There is a clicking sound from the rear when moving off (forward or reverse) and when going over to full re-gen. The splines on the drive shafts have movement caused by the adhesive used on them failing. All cases I've heard about have been covered by warranty or extended warranty. Worth a Google.
AI says,
As vedicle is outside it's original 3-year manufacturer warranty, consider these avenues to manage the cost:
Ask for Å koda "Goodwill": If you have a full Å koda main dealer service history, ask the service manager to submit a goodwill contribution request to Å koda UK. Because TPI 2065531/1 acknowledges a known manufacturing design tolerance issue, they sometimes cover a percentage of the labor or parts.
Edited by AndyMorris
Many thanks for this info.
I have asked for a breakdown of the parts required and costs
Many thanks for the info. Have asked for a breakdown of the parts and costs. Will have a better idea if the same issue you mention then...
21 hours ago, AndyMorris said:
AI says,
Many thanks for this. Once I have a definitive answer to the issue, I can use this if it is the known problem.
Many issues / faults are KNOWN ISSUES to VW Group, Dealers / Technicians. Maybe even with a TSP / TPI, yet time after time, 'Never heard of that before', never seen that before, and sometimes 'they all do that'. The VW way. 3 monkeys or Tommy. Deaf, dumb and blind. The internet really has stuffed it up for the VW group.
Edited by Evolution13
So....Dealer agrees it is the rear driveshaft issue.
They also agree that, generally, Skoda DO offer 'goodwill' financial assistance as they know it us a design/manufacturing fault.
My car has done 110k miles so basically tough **** 🤬🤬🤬🤬
That's rather poor given VAG know its a design tolerance issue.
This is the list of parts and costs for the repair (approx £1700). Plus ten hours labour (approx £1500).
Socket head bolts with inner polygon head x17 £28.90
Silicon Sealant x1 £41.37
Circlip x1 £7.30
Circlip x1 £7.30
Circlip x1 £7.30
Circlip x1 £7.30
Cap x1 £10.10
Deep groove ball bearing x1 £80.60
Oil Seal x2 £35.90
Cleaning solution x1 £33.34
Plug x1 £6.95
Driveshaft rear left x1 £545
Driveshaft Rear right £561
Gear oil x2 £113.16
Coolant x20 £109.20
Exactly my thoughts. I am going to contact Skoda directly...
Have asked Skoda UK directly for assistance. Haven't had a 'no' yet but haven't been asked for mileage yet....
Good luck. Please let us know how you get on.
Update for any interested parties...
Finally got somewhere with Skoda UK.
They offered me 20%, £650, towards the repair cost.
Better than a kick in the balls !!
I feel it would have been more for less mileage and closer to warranty expiry.
Thankyou to everybody who helped me with this....
Indeed. Glad you got some help.
