Skoda 2024 L&K 4x4 wheel alignment
I was wondering if anyone knows how often I need to do alignment on my 2024 4x4 Skoda? Do I need to go to a dealership because of 4x4 or it can be done in a local garage It is L&K with active suspension.
Maybe best not at a Main Dealer unless they have a Hunter Alignment system and employees trained to use it. Some will never have their vehicle in for alignment and others might when getting new tyres fitted. Or when have their tyres rotated. It is up to you. Regular tyre pressure checks and inspections of the tread wear in 'Simply Clever'.
I had to get my MK3 280 4x4 L&K wheel alignment checked after I noticed some really bad rear tyre wear soon after I got the car at 2.5 years old. The inner tyre shoulder was down to the canvas on on both rears. However, there was still 3-4mm of tread depth on the outer shoulder & majority of the tyre tread. Very difficult to see the inside tread wear from outside the car unless you get the car up on a ramp or get under it.
I took mine to a local alignment specialist with a 4 wheel Hunter setup. Apparently it's a well known issue with many VAG group cars that use the same back end suspension & the factory isn't that precise on how they set up the camber at the rear. Mine was out by quite a few degrees. Not had any rear tyre wear issues since (6 years & counting).
Good advice above. Best thing for this is to find a good local tyre specialist with Hunter system who know what they are doing. Some of them will deal with local motorsport enthusiasts which can be a sign that they have a good reputation.
How often you need to do it depends on how many potholes etc you hit! My local place only charge £50 if you're getting it done when buying tyres, so given the price of tyre these days it's probably worth doing if it avoids the risk of ruining a set of tyres due to bad settings.
Recently Browsing 1
