Superb 2 rear suspension sitting too low with new parts
Really stuck for answers with this one. I've owned the car for 11 years so I know its history.
I'm having some issues with my 2.0 TDI 170PS DSG FWD Superb elegance estate rear suspension sitting too low with after market parts and wondered if anyone knows the correct dimensions or what the issue could be?
2 years ago the N/S rear was catching on some speed bumps with only myself in and 2 young kids. I had the car in the garage for repairs and while fixing them, a broken coil spring was noticed. This was replaced, but the the problem never fully went away. A month later work was completed on the O/S rear and again another coil spring was replaced and at the same time 2 rear arms and 4 wheel tracking. These were pattern parts from one of the local suppliers.
The cars been catching ever since and having unloaded everything from the car recently, I could tell that the gap from rear tyre to the arch was far too low.
I took the car to a different garage who put it up on the lift. We could see scuff marks to the underside of the newish rear arms, the fuel tank and the plastic covers that run down each side of the car. We noticed a failed shocker on the N/S and decided to book it in for replacement and while the springs are out, measure them and compare the dimensions against the ones stocked at the various local suppliers.
The dimension is 368mm and the diameter of the springs on the car are the same as a new part.
Skoda themselves won't provide a spring length and say that they only use a 3 colour coding system.
We've ran various history and part checks with local after market stockists and all springs listed seem to be the same.
This then turns my attention to the rear arms, as only the springs and arms have been replaced and the ones removed will have been the genuine ones from new.
I can't buy a genuine Skoda rear arm, because they don't keep them for Superbs, and so if they order one I can't return it and they are £450 each.
I'd normally say that springs determine ride height, but it feels like the after market arms could be the issue, but would they really throw out the rear ride height by an estimated 40 to 50mm?
The fact that the arms have score marks to the underside indicates they are too low to the ground because spring length sets the vehicles ride height over the wheels and chassis. The arms can only sit lower if the geometry is different. The ones now installed have a slight camber to them and the mechanic thinks some can be straighter, so I've asked them to order a replacement pattern part to compare to whats on.
The garage needs the car off the lift so it's going to have to be assembled on Monday regardless and I might still have the same issue.
To summarise:
I have 2 rear arms and 2 rear coil springs installed from 2 years ago and the cars now sitting too low.
Currently replacing both rear shockers and damaged bump stops.
If anyone has a genuine rear spring length and or colour code it would be helpful.
@Carlston might be able top assist with specs.
Try Kilen springs as i had good experience with them as you need ones specific to an estate as it sounds like you have either sport springs or saloon springs causing it to be too low.
For the Superb MK2 2.0TDI 170HP FWD with standard ride height, Kilen list 1K0511115DF rear springs.
Perhaps try the equivalent increased ride height rear springs, ie. 1K0511115CR.
1K0511115CR is about 20mm longer than 1K0511115DF...as you might expect from an increased ride height spring.
To find out what rear springs the car left the factory with, you can use the website "skoda parts com" and put the car in the online garage using its VIN number. Then when the rear springs are searched for, only the correct ones are shown.
Sachs 994336 is sold to replace 1K0511115CR (other choices are available)
https://www.ebay.co.uk/itm/396315502720
Edited by Carlston
@ddan1275 The fact that only the spring on one side was replaced already tells the story: The "garage" doesn't understand his job. Suspension parts like springs (and shock absorbers etc) should always be replaced on both sides!
The fact that the car is now lower than it should be is another indicator for the poor competence of your "garage". Most likely the new springs are not stiff enough for your Superb.
This also leads you to the solution: Go to a proper garage and have them fix your car with quality parts with the correct specifications. You don't have to go OEM, after-market parts from A-grade suppliers (Sachs, ZF etc) are also OK.
About you wanting to measure free spring length: That length says absolutely nothing about the spring stiffness, so there is no use in measuring it. In this case your Skoda dealer is right: Just use a set of springs from a well-known brand with the correct color code, and your ride height will be restored.
See the attached Word document (sorry, it's in Dutch, but the picture should be clear).
The dimension "a" should be
  • 394 ± 10 mm for standard suspension
  • 379 ± 10 mm for sport suspension
  • 414 ± 10 mm for rough road suspension
Voorgeschreven waarden achteras.doc
Edited by andrehj
Recently Browsing 1
