Electric boot Struts
There is a post open on this recently but no one seems to be answering my query so apologies for another post on same subject...
When I press the button to open the boot from the keyfob, it opens about 6" then closes again. If I open using the button on the boot, it opens the same distance but just sits there. When I manually push it up from this position, there is a certain amount of resistance and when open fully and I press the button on the boot to close it ,bleeps about 6 times and does nothing. Are there likely to be any fault codes that would indicate what the issue may be? I can`t think it would be a break in a wire as I`m guessing it wouldn`t open at all. If it were a faulty strut , how would you ascertain which one? or is it likely both could be faulty? Or indeed could it be something else entirely?
