Electric boot Struts
There is a post open on this recently but no one seems to be answering my query so apologies for another post on same subject...
When I press the button to open the boot from the keyfob, it opens about 6" then closes again. If I open using the button on the boot, it opens the same distance but just sits there. When I manually push it up from this position, there is a certain amount of resistance and when open fully and I press the button on the boot to close it ,bleeps about 6 times and does nothing. Are there likely to be any fault codes that would indicate what the issue may be? I can`t think it would be a break in a wire as I`m guessing it wouldn`t open at all. If it were a faulty strut , how would you ascertain which one? or is it likely both could be faulty? Or indeed could it be something else entirely?
So after googling and a bit of youtube, had a look at the left hand side and found the green wire broken and the yellow on the way. Hadnt got any wire the same size and was a job to get the boot back over but two pieces soldered in with heatshrink and the boot now works as it should.. Will do for the time being, but will eventually get a couple of replacement struts when it goes again..
