skoda octavia 2025 tsi 1.5 manual
Hi everyone i have a fairly new skoda octavia 2025 tsi 1.5 manual the fault is it cuts out at trafic lights or braking at slow revs sometimes and takes a few goes to restart the dealer says they cant see a fault code has anyone else had this problem ? i usually use auto hold for stopping and disable start stop.
Seems to be a "feature". there's a long discussion on the Karoq forum
Same problem with the Seat Leon, this problem seems to be through the whole VW 1.1 & 1.5 4 cylinder engines.
Octavia 4.5 with manual gearbox: Yes, I have had this a few times. If the revs drop too low in third approaching a junction it will cut out, sometimes even in second with the wheels still turning. It's not a huge issue. I always use Shell VPower but don't know whether that makes a difference either way.
ive had this issue too, you need to keep the revs higher. its actually stalled before you have come to the lights, but there is no indication it has.. no juddering or anything of the sort, its not until you come to a stop you realise or go to set off again.
2025 1.5tsi manual
i'd actually drove 4 other skodas, two octavias, a superb and kamiq and didnt have this issue
Edited by zith
